Getting your nuts off !!
Old May 3, 2010 | 01:35 AM
Stewart Allison's Avatar
Stewart Allison
Default Getting your nuts off !!
Just a quick one. Some time back I received an email of a chemical concoctions of removing rusty bolts and nuts.
The winner was Auto Trans Fluid & Acetone. Now what I was wanting to know how can I keep this 50 -50 mix together in a spray application. Surely a plastic spray bottle of this mix wouldn't last in the plastic bottle. An oil can might work but no good if spraying is required. Can anyone suggest a way of keeping the mix in a spray applicator. Or is there a metal spray applicator on the market..... Stewy
Old May 3, 2010 | 02:33 AM
GEM '62's Avatar
GEM '62
You may be over thinking this. ATF comes in a plastic bottle. I purchased a plastic bottle of acetone at a craft store, so unless the mixture of the 2 will combind to destroy plastic then you should have no problem with a plastic spray bottle. I would give it a try and see what happens
Old May 3, 2010 | 03:47 AM
Stewart Allison
Yeah all the Acetone over here is metal tin. I could be wrong but mine are tin. I will try a mix and see how it turns out. I hate mixing different chemicals together I always think it will go bang..... I'll try it ! Stewy
Old May 3, 2010 | 08:06 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
I read that too and was pretty amazed....I wouldn't mind having some of that Acetone/ATF solution in a spray bottle laying around. (Sooner or later I'm gonna have to tackle the rusty bolts on my boat trailer). Pls let us know if your method of storage works.
Old May 3, 2010 | 08:16 AM
Stewart Allison
I'm fanging just to try it on some rusty bolts !!! Stewy
Old May 3, 2010 | 08:18 AM
VetteJohn's Avatar
VetteJohn
Default Metal container
Stewy,
I use a metal, refillable container that you pressurize with compressed air. I use this for brake fluid but it should work for the evil concoction you're mixing up.
Old May 3, 2010 | 08:26 AM
Stewart Allison
Originally Posted by VetteJohn
Stewy,
John have you a photo of your container..... Stewy
Old May 3, 2010 | 08:38 AM
w1ctc's Avatar
w1ctc
Use an old paint spray gun hooked to a compressor or air tank of some kind.
Old May 3, 2010 | 08:44 AM
Stewart Allison
That's inventive.......... Stewy
Old May 3, 2010 | 09:24 AM
wombvette's Avatar
wombvette
What about an Afrin nose spray bottle?
Old May 3, 2010 | 09:28 AM
Stewart Allison
I might be tempted to spray it up my nose. I have a drug problem LOL Stewy
Old May 3, 2010 | 09:49 AM
Powershift's Avatar
Powershift
Stewy:
Acetone is also one of the components in lacquer thinner....and is good at removing lacquer and other paints. Use with care around your car so that you don't have unintended consequences
Kroil is/appears to be safer to use around the car. But it is somewhat difficult to find and is a bit $$.
Larry
Old May 3, 2010 | 12:17 PM
rengawdor's Avatar
rengawdor
I bought a couple extra spray bottles from Captain Al - the ones used to spray his paint remover. I keep lacquer thinner in one, and use it to spray on items I want to clean, as opposed to dumping some on a rag (and spilling the rest all over the place). In a regular spray bottle, Lacquer thinner breaks down the rubber seal (and sometimes the plastic) in a couple hours. The Captain Al bottle has lasted 3 years so far......
Rod
Old May 3, 2010 | 06:20 PM
Stewart Allison
Originally Posted by Powershift
Stewy:
Larry
Good point and I don't want any auto trans being left to soak into the fibre glass.......Stewy
Old May 3, 2010 | 08:37 PM
GUSTO14's Avatar
GUSTO14
A product I have heard about for years but rarely found at retail outlets is Kroil. I've used a lot of penetrating oils over the years but none I've tried works as well or as fast as Kroil.
You can go to their website and purchase directly. They're even offering a free can of AeroKroil (Kroil in an aerosol can) with any purchase...https://secure.concentric.com/kanola...er_kroil.shtml
Good luck... GUSTO
Old May 4, 2010 | 12:19 AM
Stewart Allison
Good luck... GUSTO
Hey gusto what's with the plane in your Avatar. Surely it doesn't take off like a helicopter ?
Old May 4, 2010 | 12:47 AM
Mark_Milner's Avatar
Mark_Milner
Why not just buy a can of PB Blaster?
I am pretty old school with Liquid Wrench, but I found PB Blaster to work pretty well.
To Getting your nuts off !!
Old May 4, 2010 | 01:54 AM
knight37128's Avatar
knight37128
Good luck... GUSTO
You may have to wait a few days for it to ship.
Nashville is flooded at the moment.
Old May 4, 2010 | 03:16 AM
narlee's Avatar
narlee
I read a rating chart a while back and Liquid Wrench was rated quite high. I can't remember if it was Kroil or PB Plaster that was higher. I've had good luck with Liquid Wrench and just got some Kroil but haven't used it yet.
Old May 4, 2010 | 09:51 AM
Wondertoad's Avatar
Wondertoad
There is a portable sprayer made by an outfit called Preval. The sprayer has a glass bottle about the size orf a large baby food jar and a disposable aerosol type cartridge that propels the mixture to be sprayed. These can be bought a model shops and some hobby stores.
I am sure that this would work, the only question would be the length of time that the propellant cartridge would keep its charge.........
B Cochran
