327 Flywheel
Old May 4, 2010 | 02:54 PM
TX63CONV's Avatar
TX63CONV
Default 327 Flywheel
What were the specs on a 63 340hp flywheel? 153 tooth? PN 3791021?
I am looking for a good used one or a reasonable replacement. Machine shop wants the flywheel to balance the 327 build that I am working on. Original flywheel (I hope) is on the NOM that is in my current driver.
Any thoughts on tracking one down?
Old May 4, 2010 | 03:02 PM
MikeM's Avatar
MikeM
Any Chevy II four, six or eight cylinder from '62-'67.
Any Chevelle six or eight cylinder from '64-??
Pass car, the same way.
Corvette '63-'??
In other words, there were tens of millions made. Don't be bashful.
Why does the machine shop need a flywheel to balance the rest of your rotating assembly? They should be able to balance without it.
Old May 4, 2010 | 03:29 PM
Donny Brass's Avatar
Donny Brass
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I'd take this opportunity to buy a new one.... 45 year old cast iron is not the way to go.
Old May 4, 2010 | 03:33 PM
TX63CONV's Avatar
TX63CONV
Corvette '63-'??
They all used virtually the same one? 153 tooth? I dont want to spend the big bucks for a new one if I can pick up a usable one at swap meet.
Not sure why he wanted the flywheel. Its internally balanced. They have done a good job for me in the past.
Old May 4, 2010 | 03:38 PM
midyearvette's Avatar
midyearvette
buy a new one....jmo.....
Old May 4, 2010 | 07:24 PM
JBL Specialty's Avatar
JBL Specialty
If you are going to replace your flywheel,why not use the flywheel from a 84-85 c4 with the 2 piece rear seal . its the same flywheel used on the 396-425 and the L-88.the engine will rev faster because it has less rotating mass.
Old May 4, 2010 | 07:36 PM
narlee's Avatar
narlee
How much does the stock flywheel weigh?
Old May 4, 2010 | 07:48 PM
Jackfit's Avatar
Jackfit
Default Light is better in my opinion
Hi, picture of my stock flywheel 66 L79 327/350 weighs in about 35 lbs.
When I rebuilt engine, Blockman suggested a lightweight flywheel at 15 lbs.
Had it balanced and matched to clutch and boy , with my 3.70 rear and wide ratio 4 speed, it makes a difference. You do have to get used to faster revs and faster loss of revs.
But I have the stock flywheel on the shelf.
Jack
Old May 4, 2010 | 08:07 PM
jim lockwood's Avatar
jim lockwood
I can't think of a reason, other than stinginess, to trust ancient metallurgy.
Jim
Old May 4, 2010 | 09:11 PM
midyearvette
im pretty sure that wheel is for an externally balanced engine bwdik?
Old May 5, 2010 | 07:35 AM
MikeM's Avatar
MikeM
Somebody please tell me how a flywheel "goes bad" just because it's old?
Worn, heat cracks, surfaced too many times, been sunk in a swamp or other abuse, yes. Age, ?????????????????????????
Old May 5, 2010 | 09:14 AM
Donny Brass
heat cycles.......
http://www.460ford.com/forum/showthread.php?t=138991
Old May 5, 2010 | 09:26 AM
MikeM's Avatar
MikeM
That's pretty dramatic. 800 hp? That would come under abuse, heat cracks or?????????
What does that have to do with age?
Old May 5, 2010 | 10:16 AM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Jim
JIM!!!!!!
You ever heard of a cheapskate?
I wrote the book!
Tom Parsons
Old May 5, 2010 | 11:57 AM
jim lockwood
I wrote the book!
Yep, Tom, I've read your book but I must have skipped the chapter about flywheels!
Jim
Old May 5, 2010 | 12:25 PM
63 340HP's Avatar
63 340HP
For the cost, I would get a new flywheel and upgrade to a steel SFI Certified flywheel.
This Flywheel Link gets you to some moderately priced SFI flywheels that are superior to the stock iron. You have a choice between 18# and 29# models for a 327'.
I understand that NCRS does not judge a flywheel, so a steel SFI flywheel is one area where a safety upgrade is not in conflict with a goal of zero judged point deductions.
To 327 Flywheel
