A-arms
Is there a way to check and make sure the A-arms are straight? I'm getting ready to rebuild the front end components and paint/powder coat them and thought I should check prior to rebuilding the components. I had no issues with how it handled.
Thanks Brian
Thanks Brian
jack
If you took them off the car and have not had a front end problem, they should be OK. Be careful on the powder coating not to get it on the exact surface such as threads and where the control arm bushings are pressed in. The stuff builds up and causes, in some cases, VERY tight specs, especially on threads.
Dennis
Dennis
