L79 cam & CR
My opinion is that you need an honest 10 to 1 compression ratio to make things work correctly with the L-79 cam.
Let's see if others agree.
I believe 9 to 1 won't make you happy.
Larry
Larry
Received 1,843 Likes
Dunno what the lowest is but mine runs well on 89 octane with the factory domed pistons advertised at 11.25-1. I'm sure that's not actual ratio but whatever it is, it works. I wouldn't worry about the lowest compression, I'd build it back to stock spec but that wasn't your question.
When you take compression away from these performance camshafts, you'll wind up with a soggy feeling engine.
I have no idea how low "acceptable" is but it wouldn't be any less than a stock spec build for me.
I agree with you but unfortunately, sometime ago I was convinced to go with flat top pistons on my build. Since then, I've had the pistons mounted on the rods and the rotating assembly balanced. Soon I'll know my achievable CR when I determine piston to deck clearance. If I can't achieve an "acceptable" CR that is compatible with the L79 cam, seems that I have two choices...1) change the cam or 2) purchase dome pistons and have the rotating assembly rebalanced. Am I right?
A long time ago, I put an L-79 cam in a 300 hp '65 Chevy II. The car ran noticeably better. I then put a Rochester FI on the engine. It ran better yet.
It would not keep up with my car, which was a virtual twin except I had the factory domed pistons and slightly larger valves, but it wasn't far behind. I believe that would make the engine in that 300 similar to yours except for valve size.
Even if you are using the stock 62-64 cc heads, a block deck that hasn't been cut, factory flattop pistons with the stock compression height and typical thick, blue, Felpro head gaskets, I think you'll be happy. You just won't have all you could have. If you've decked the block, so much the better.
Too late to worry about it now unless you like spending a bunch of money for little gain.
With flat tops you are about 9:1 and as said you'll have a dog with that cam. You would be better off running the 300hp cam or swap out for the correct pistons. I run a true 10.25:1 in one of my cars with the L79 cam and it runs awesome on premium gas.
Something like a 214 to 220 adv duration cam on a 110 LSA will work very well in a flat-top piston 327 w/ ~9.5:1 CR (where they typically end up with flat-tops and OEM advertised 64cc heads). A cam like this will give you a slight bit of a lumpy idle due to the 110 LSA, and will sound very similar to an L79 cam. The earlier intake valve closing allows the cam to perform well with the low CR.
I have an actual 9.3:1 327 in my Chevy II w/ a Reed Cams 264/272, 214/218, .450/.460, 110 LSA cam. If you search You Tube, there is a 'stock 65 Chevelle L79 idle video on there. The sound of my car is not too far from the way this Chevelle sounds. Idle is basically smooth with just a hint of lope - enough to let you know it has a cam, but not enough to shake the car.
A 300 hp cam is not a performance cam by any stretch.
If I could achieve 10:1 with the FTs, would the performance with the L79 cam be respectable? Heads and block have been decked to clean up the surfaces. Don't know if they were decked before me.
With cleaned up deck, cleaned up heads, stock compression height on flat top pistons, you'll be okay.
Are you looking for more opinions or what?
I remember when you asked about the choice of pistons for this engine and a number of people told you to use the domed replacement but you chose the flattops. Deal with it, you'll be okay but would have been better off with the domed pistons.
72 LT-1s were 9.5 to 1 compression and ran the 70 1/2 Mech. cam. They ran exceptionally well. Was the L-79 cam that much different?
There is no line drawn in the sand at which point compression ratio becomes unacceptable/acceptable.
I think you will be fine unless you want to spend a lot of money to fix something that isn't really broken.
If you are at 10:1 you will be great, factory cars were closer to 10.25-10.5:1 than their advertised ratio anyway. If you need a thinner head gasket you can use the hypalon coated fel pro 1094 at .015" or anywhere in between the standard thickness fel pro's.
One thing to pay attention to since the block has been decked and maybe the heads milled is your intake to head seal since the mating geometry has been altered. Not knowing how much material has been removed, you may need to have your intake milled to match.
The L-79 is the 350hp cam. Which was also running in the L-82s until 79. If my memory serves me correctly. Which it sometimes doesn't.
