Clamps
Old May 15, 2010 | 01:06 PM
mgoeppert's Avatar
mgoeppert
Default Clamps
I am trying to figure out which clamps go on the short hose from the overflow tank to the tee. The AM shows the spring style at the tee but does not show which style at the tank nipple. Long Island sells the band style for both but that conflicts with the AM. Could use a little help.
Mark from Ripon,CA
65 roadster L/79
Old May 15, 2010 | 03:59 PM
Bill Irwin's Avatar
Bill Irwin
Mark, on my 67, same engine, they are both the spring clamps. I think the name is a corbin clamp. Hope this helps. Bill.
Old May 15, 2010 | 04:35 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Bill and Mark:
A corbin clamp is found on a lot of lawn mowers. It is the flat band clamp that can be installed with a pair of pliers by holding the three tabs together while you slip it over the hose and then when you release the tabs one side has two and the other side has a single in the center of the two.
Rich
Old May 15, 2010 | 04:50 PM
Bill Irwin's Avatar
Bill Irwin
Rich, thanks for the info re corbin clamp. I have seen them. Is there a name for the spring type we're talking about? Bill
Old May 15, 2010 | 05:46 PM
mgoeppert's Avatar
mgoeppert
Thanks gentlemen,
spring it is/Mark
Old May 15, 2010 | 06:07 PM
Mike Geary's Avatar
Mike Geary
Default You might want to recheck the AIM
the clamps for the short hose are screw clamp-style, just like LICS sells.
Check AIM UPC 11-13, sheet A5.
I try to remember to install this shorty hose on the tank BEFORE putting the tank in.
And Corbin clamps are the spring WIRE style, as used on your heater hoses.
Old May 15, 2010 | 06:22 PM
ricks327's Avatar
ricks327
Here is a photo (not the best) of the back side of the band clamp.
Rick
To Clamps
