Engine ID Hepl
May 23, 2010 | 08:43 PM
Engine ID Hepl
Hello
Now that the engine is out of the 66 Coupe can someone help with decoding the numbers Please
GM 385174
Front Pad 6120592 FO22HT
Bill
May 23, 2010 | 08:51 PM
I assume it's 3858174, which would be 64-67 327, and HT is the code for 327-350hp. Original engine to the car?
May 23, 2010 | 09:37 PM
1966 engine code
Hi Bill
There should be one more number in the engine assembly date. That's the F022HT number you posted. Could it be F0422HT. In the example I provided it would be F=Flint, 04=April, 22=day of the month and HT=code for 323/350HP
Regards
Page Campbell
May 24, 2010 | 07:22 AM
2024 C1 of the Year Winner - Modified
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
The 6120592 is the serial number. The 6 is the year 66. It would be the 20,592 built in 66.
May 24, 2010 | 08:42 AM
Thank you
Wow this is the best place to get the correct information regarding the Corvette marque
Thank you
BuffaloBILL
May 24, 2010 | 10:41 AM
Quote:
Originally Posted by
snydes
The 3858174 block was only used in '66 in Corvettes.
May 24, 2010 | 08:53 PM
JohnZ
Just did a quick check on Mortec's website and thats what it said, perhaps used in other models in earlier years??
May 25, 2010 | 01:30 PM
snydes
The 8174 block had
lots of other applications from '64-'67 in Chevelle, passenger, Camaro, and trucks, but was only used in Corvettes in '66.
