Cam Selection
I thought I had narrowed it down to two: the L79H and the 30-30H from CompCams. So I called their support line for some advice. I am not very technical when it comes to cam shafts and specs (I’m sure I sounded like an idiot
) and so I made the mistake of asking the guy would he recommend something else based on the info I had given him. “Absolutely” was his response. “I would go with an xtreme energy 268H cam….you are comparing 30 year old cam technology with new technology”Here are the specs for the cams:
L79
Duration at .050 lift: 229/236
Valve Lift: 468/462
30-30H
Duration at .050 lift: 239/246
Valve Lift: 483/477
268H
Duration at .050 lift: 224/230
Valve Lift: 477/480
The specs for my engine build are:
+ 327 small journal 040 over
+ estimated 10.5 compression
+ rebuilt 64cc double hump heads
What I want:
Looking for a nice idle but not sounding like a drag car, a nice pin you in your seat power band. Will never rev it over 6k (probably not over 5k). I know there are some good solid lifter cams but I know my comfort zone. Looking at the cam specs, is there anything that I should focus on when making my decision? Anyone ever used their xtreme energy cams?
It is much different than the 30/30 which does not have the low to mid range characteristics of the L 79. I have owned both and will always favor the L 79. Just remember that both of them require solid compression (11:1) to make them effective.
Some of these aftermarket replacement cams use the same duration/lift as the GM cam. BUT, once the valve opens, they accelerate the valve very quickly, hold it open longer and then let the valve slam shut. This, they call "modern technology" or it could be called a "cheater cam". There is nothing "new" here.
Those cams sometimes cause problems pulling rocker studs, breaking rockers, having to use stiff valve springs and yes, flat cam lobes due to extreme spring pressure.
Use the real McCoy.
I run Canfield aluminum heads and my block is a 69 vintage 350. My compression ratio is right at 9.5 and it pulls smoothly from about 1100 rpm to over 5000 rpm. Power just keeps coming on until you lift.
I also run TPI so basically what I have is an L-98 with better heads and cam than the factory used. I'm very happy with it.
Rich
The 327-350 and the 350-350hp cams are the best all around hydraulic grind.You don't need the mech. cams if you aren't going over 6000rpm anyhow.
We ran a 268H in a 350 back in 1984. The engine ran ~10:1 CR, with well ported 186 heads that used the smaller 1.97 intake valves with 1.6 exhausts. With the 268H cam it would lay down around 5000 rpm. We tried Rhodes lifters and a number of other things to improve the top end, but we did not gain much.
We swapped it out for Engel's version of the L79 cam, basically advanced four degrees from stock L79 specs to work better with the lower compressor, and the car went faster and ran clean to 6000 rpm.
Use the L79 (unless you want to run the 097 solid lifter cam with 1.6 rocker arms).
With your experience with the 264, what is your opinion of going a step up to the 270 for a daily driver type vehicle with 200-4r trans and 3.5 rear in a 2500-2700 vehicle?
Logic tells me to go with the 264, and EA shows better low and mid range torque than with the 270, without much sacrifice on top end, but I have always been a sucker for bigger is better, and I don't want too much dynamic compression with the 10.3 CR. IIRC, the 264 gives me 8.18:1 DCR and the 270 gives about 7.8:1 DCR.
Oh, yeah, headers, full exhaust, Edelbrock performer airgap RPM, Holley 650 spread bore 6210 double pumper.
Thanks, and sorry about the thread hijack
Doug
Doug
Doug:
I have a 336 gear and run a TH350 in a 3200 lb car. I run Heddman 1 5/8 side exit headers with 3" collectors into 2" factory side pipes. At 70 mph I am running right at 3000 to 3100 rpm because I have no overdrive.
The Canfield heads have 2.055 intakes and 1.6 exhausts. Chambers are 66 cc. I also run 7/16 rocker arm studs and Comp Cams Pro Magum full roller rockers.
With factory 24 lb injectors the TPI ran too rich so I changed to Bosch 22 lb injectors. I run 43 lbs of fuel pressure on the rail at idle. For myself this combination is a winner.
We ran the 270XR in my son's 87 Corvette with a 383 and stock Chevrolet aluminum heads from his car. He had the rear end changed to a 390 and ran a 700r4 trans. Car would come out of the hole like a funny car but wasn't that impressive above 70 mph. Seat of the pants feel was that it kind of flattened out, especially when compared to the hole shot. Might have been the lack of a good cylinder head to go with the rest of the motor.
Comp Camps says the 270 is the largest cam you can run with a stock style converter.
My personal opinion (and that is all that this is) would be to go with the 264.
Rich
will sun great.
Use the real McCoy.
.. Flat tappet cams aside the 'new' cam dynamics sound better suited to a roller cam design. The factory engineer boys back in the 60's knew a thing or two about cam design.
Bob
http://www.northernautoparts.com/Pro...entoryId=35007
DT
