60 temperature sending unit test
Shouldn't there be absolutely no movement, zero, with the wire off and the key turned on?
With the wire off and then grounded the Gauge will peg to full hot.
This is what I have done so far.
The problem: After 10 minutes of running the temp gauge will slowly move to full hot and stay there. This only happens after running for about 10 minutes. I know that this temp is wrong and it is really running at 180.
2: Disconnected the temp sender wire at the engine, and disconnected the other end from temp gauge (right post). Ran a test wire from the temp sender over the windshield to the temp gauge right post, and with the key on the gauge went to the first 0 on the 100 temperature gauge dial. This means that the needle moves up about an 1/8 of an inch up from dead cold.
3: With the temp sender disconnected and the key on, the gauge will go to the 1 on the 100 temperature gauge, so it is not going as high as #2.
4: Tried different brand senders, the same results.
5: With a multimeter on the right post, and one to a good ground, and with the key on I get 12.46 volts. With the key off I get .03.
6: With the temp sender wire grounded to the engine, the temp gauge will immediately peg full hot.
Next the sender should be somewhat close to these readings (attached) depending on the brand. If the sender is close then its something in your wiring or dash gauge.
PS I assume you know not to use any Teflon tape when you install the sensor.
I have also used Dewitts sender $30, I did not pan test it. Tried it dry, it leaked, tried with teflon, and per Tom's recommendation, tried it with never seize.
Thanks!
