Flasher
Old Jun 13, 2010 | 11:43 AM
daxmann's Avatar
daxmann
Default Flasher
I'm sorry for being the dumbest person on this site but can someone please show me the location of the flasher so I can get my turn signals to work. Thanks.
Old Jun 13, 2010 | 11:44 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
First you have to tell people what kind of car...if its a later C1 the flasher is in the fuse box.
Old Jun 13, 2010 | 11:49 AM
62Jeff's Avatar
62Jeff
And if it's a 63-67, it's clipped to the side of the center dash, on the driver's side radio cover panel. It is up high, near the bottom of the instrument cluster on the right side.
Old Jun 13, 2010 | 12:12 PM
daxmann's Avatar
daxmann
Default 64
The car is a 64 and I have removed the instrument cluster and the air duct on the side of the center dash but still no relay. The turn signal dash lights went on for the right and left blinker but would not flash. Is there something I'm missing?
Old Jun 13, 2010 | 12:18 PM
JohnZ's Avatar
JohnZ
That started in '65 - on '63-'64, the turn signal flasher plugged into the top corner of the fuse block.
Old Jun 13, 2010 | 12:19 PM
62Jeff's Avatar
62Jeff
Ack! Thanks John. A humble retreat back to my couch is in order!
Old Jun 13, 2010 | 12:31 PM
daxmann's Avatar
daxmann
Default Thanks
Thanks for the help JohnZ and 62Jeff. It has been replaced.
Old Jun 13, 2010 | 01:53 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I always put my head under the dash, turn the key on, put the signal on, and follow my ears. Pretty easy and works on all cars!
Old Jun 13, 2010 | 01:56 PM
Ron Miller's Avatar
Ron Miller
That might have worked in his case as well, but I think he'd have had to open his eyes as well and not depend upon his ears. With the flashers not flashing the turn signal lights there'd be no noise to listen for!
BTW, I'm assuming the replacement did cure your problem, daxmann.
Old Jun 13, 2010 | 02:26 PM
Kerrmudgeon
Originally Posted by Ron Miller
....... I think he'd have had to open his eyes as well and not depend upon his ears. With the flashers not flashing the turn signal lights there'd be no noise to listen for!
Sorry, I was assuming open eyes, forgot about the not working part, still not hard to find with a light, they are all standard size and shape.
Old Jun 13, 2010 | 03:55 PM
Ron Miller's Avatar
Ron Miller
I suspected you were assuming his eyes were open as well, I just had to rib you a little. It's a slow Sunday here, not too much going on . . . . as you may have already suspected.
Hope you guys are having a little cooler weather today than we are here in southern Missouri, reaching the upper 90's here, approaching 100 F.
Old Jun 13, 2010 | 04:08 PM
vt65's Avatar
vt65
send us some it's 45 deg f here, yesterday it was 90 and muggy! My ex-Missouri car is shivering !
Old Jun 13, 2010 | 04:56 PM
Ron Miller's Avatar
Ron Miller
If I only could . . . . . there's plenty here in need of exporting, for sure!!
To Flasher
