correct ride height
Old Jun 20, 2010 | 12:17 PM
TDE67's Avatar
TDE67
6th Gear
Default correct ride height
Can anyone tell me the correct ride height, as measured from the ground to the top of the wheel well arch, for a 67 big block C2 convertible? Looking for both front and rear measurements. Thanks and regards.
Tom
Old Jun 20, 2010 | 12:27 PM
DansYellow66's Avatar
DansYellow66
Readers will post what there measurements are for comparison, but there are too many variables such as body to frame shimming, body assembly tolerances and tire size for them to be of much use. The factory service manual has the factory ride heigth tolerances and diagrams of how to measure them. It's a comparison of difference between lower ball joint heigth and lower control arm pivot bolt centers from memory and without looking it back up.
If you post your tire size you might at least get a few comparisons based on like tire dimensions. That will get you 40% of the way there but it's not going to be close enough to tell you much.
Old Jun 20, 2010 | 12:43 PM
TDE67's Avatar
TDE67
6th Gear
DansYellow66,
Thanks for the quick response. Understand your discussion on ride height variables. Any chance you can quote me the factory ride height tolerances from the service manual. I don't have the manual.
Another related question. Should the height to the top of the wheel wells be the same for the front and the rear, all other variables taken into account.
Thanks again and regards
Old Jun 20, 2010 | 01:17 PM
JohnZ's Avatar
JohnZ
GM never published ground-to-fender lip ride height dimensions for '65-up Corvettes; the enhanced charts below (thanks, Buns) show how to measure the front and rear ride heights, independent of tire diameter. These charts are in the '67 Assembly Manual, which you should have, along with the '67 Chassis Service Manual.
Old Jun 20, 2010 | 01:20 PM
MikeM's Avatar
MikeM
Originally Posted by TDE67
DansYellow66,
The answer to this question is the same as the first. Depends. There's enough leeway in the spec to make a definite difference front/rear. Maybe as much as two inches.
My '63 SB convertible measures 26 1/2" at the front wheel character line and 27 1/2" at the rear. Standard springs, 205/75 tires. That gives it about a one inch forward rake and I believe that is typical of SM cars with standard springs. F-41 springs and/or BB will alter the height.
Still, I believe a slight forward rake was/is typical if the factory springs are still under the car.
Old Jun 20, 2010 | 03:20 PM
magicv8's Avatar
magicv8
Body height is (GM Restoration Guide spec) 8 inches at the bottom of the rocker panels. (12.5 from the body crease for sidepipes
1966 AIM A152 lists 8-9 inches as shipped.
PS - let the flames begin.......
Old Jun 20, 2010 | 03:48 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Mine measures the same. Eaton non progressive rate springs. Gave me 26 1/2 in front and 27 1/2 in rear with 27 inch diameter tires.
Old Jun 20, 2010 | 04:15 PM
1965fuelie's Avatar
1965fuelie
2018 C2 of Year Finalist
My 65 coupe is 26" front and 26" rear on 205/75R15.
My 67 roadster is 25,5" front and 26" rear on 215/70R15.
Old Jun 21, 2010 | 08:51 AM
TDE67's Avatar
TDE67
6th Gear
Default ride height
Thanks everyone for you responses. Most helpful.
Regards
Old Jun 21, 2010 | 06:06 PM
BANG11's Avatar
BANG11
How much does the motor being out affect ride height? Mine is out right now as it's had a complete chassis rebuild and the drivers fender is at least 1.5" higher off the wheel.
Old Jun 21, 2010 | 06:31 PM
MikeM's Avatar
MikeM
I hope when your front end was rebuilt, they tightened all the upper/lower shafts and sway bar with the front end at ride height.
The front end would probably come up 3-4 inches with the engine removed. That's just a guess.
Old Jun 21, 2010 | 07:33 PM
MiguelsC2's Avatar
MiguelsC2
Quite a bit. Kinda like having 3-4 linebackers sitting on your front end.
Old Jun 21, 2010 | 07:39 PM
BANG11's Avatar
BANG11
I was told they were not to be tightened until the motor was installed, is this not correct?
Old Jun 22, 2010 | 12:55 PM
JohnZ's Avatar
JohnZ
Yes, that's correct - they shouldn't be torqued until the car is complete and at normal ride height. In the plant, we used compression fixtures on the Frame Line to put the suspension at normal ride height while all of those attachments were torqued.
Old Jun 23, 2010 | 11:06 AM
yukonranger's Avatar
yukonranger
On a related note, is there are difference between the ride height of the standard suspension and the F40/F41? I don't see anything in the AIM about a difference but some other sources suggest that there is.
Old Jun 23, 2010 | 11:47 AM
MikeM's Avatar
MikeM
See post #5.
Old Jun 23, 2010 | 04:11 PM
magicv8's Avatar
magicv8
I don't think so. There are at least 4 different factory front spring rates/heights to cope with big blocks, A-C and racing/stiff suspension, and 2 rates at the rear that left the factory at the same height.
To correct ride height
