disc brakes without a conversion kit?
Old Jun 22, 2010 | 04:26 PM
63vetteguy's Avatar
63vetteguy
5th Gear
Default disc brakes without a conversion kit?
Hi guys my name is John and I have a 63 rag top that I want to put disc brakes on but I don't want to spend 1000 bucks on a kit. Is there any other way to add disc. I can weld and I have access to a machine shop. Thanks
Old Jun 22, 2010 | 04:31 PM
66jack's Avatar
66jack
are you serious?
Old Jun 22, 2010 | 04:32 PM
1963GrayGray's Avatar
1963GrayGray
2025 C1 of the Year - Unmodified Finalist
2020 Corvette of the Year Finalist (stock)
2019 C1 of Year Winner (stock)
Default C2 disc brakes
John, The brakes on my 63 were all removed from a 74 including the MC and front spindles. The parts were from a wrecked car. They have been working well for about 15 years, including a number of days at the Autocross course.
Dave
Old Jun 22, 2010 | 05:04 PM
Ron Miller's Avatar
Ron Miller
I don't believe the drum brake cars have provisions for mounting the brake calipers. The easiest way to accomplish the conversion would be to replace the '63 front spindles and complete rear trailing arms with ''65 or later parts, I believe. But, I'd doubt you'd be able to accomplish that for less than the $1000 figure you quote.
Old Jun 22, 2010 | 05:36 PM
63vetteguy's Avatar
63vetteguy
5th Gear
Thanks Dave and Ron. I will see if I can find out some more information. I will try and find some 74 parts for mine.
Old Jun 22, 2010 | 05:59 PM
TheSaint's Avatar
TheSaint
I have front spindles/the hole assembly from a 1974. Just had the spindels and the rest of the parts painted and new bearings/dustshiled insralled
I have ordered a complete set of trailing arms, master cylinder/booster, calipers, rotors and brake lines from Van Steel
On a 63 if you are going for disc brakes at the rear as well i think you need to do a little welding on the frame because of the parking brake
Old Jun 22, 2010 | 06:54 PM
gbvette62's Avatar
gbvette62
You can do the conversion using any 65-82 front and rear suspension, not just 74. You will need the front spindles, hubs, caliper brackets, calipers, rotors and backing plates. You can reuse your upper and lower a-arms, tie rod ends and the rest of the steering. For the rear you will need complete rear trailing arms, calipers and rotors. The actual stamped steel part of the 63 arms can be modified to use with the discs, but you still need the 65 up spindles, caliper brackets, etc. so it really makes more sense to use the newer ones. 63-64 trailing arms don't have much (if any) core value as a trade in toward rebuilt 65-82 arms though. I would also use a 67-76 dual master cylinder, a 67 proportioning valve and bracket and a 67 brake line kit. This would give you a bolt in and safe set up that would be easy to repair and maintain, as all parts would be factory based.
Unfortunetly, I highly doubt that it can be done for a $1,000 or less, especially if you planned on using rebuilt, stainless sleeved calipers and rebuilt trailing arms. I know that if I was doing this swap, I wouldn't go to all the effort and then install old used calipers and rotors or trailing arms that didn't have fresh bearings.
Old Jun 22, 2010 | 07:10 PM
TX63CONV's Avatar
TX63CONV
You will easily spend $1k on the rear trailing arm set up alone. I would look into the front brake conversion using 65-82 parts (I think the bigger 75(?) up spindles are cheaper).
Check out www.duntovmotors.com. They bought my 63 hubs and spindles and it was enough to where the front end conversion was not that expensive. You will still need calipers, rotors, MC and proportioning valve but these you should be able to buy at NAPA or another LAPS.
Good luck.
Old Jun 22, 2010 | 07:13 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I've got the front suspension off a 78 I can sell real cheap ! it will bolt up.
Gregg
Old Jun 22, 2010 | 07:21 PM
63vetteguy's Avatar
63vetteguy
5th Gear
Thanks guys for all the response. Sounds like i have more option than i thought. Gregg if you can send me a pic of what you have to my email and a price I would like to have a look see. thanks jtcrayton@ctc.net
Old Jun 22, 2010 | 07:25 PM
63vetteguy's Avatar
63vetteguy
5th Gear
The front conversion kit is on ebay for 849.00 for red wilwood calibers
Old Jun 22, 2010 | 07:30 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
front disc/drum rear will easily get you by until you can save up to do the rear...
Bill
Old Jun 22, 2010 | 07:50 PM
mashinter's Avatar
mashinter
FYI: This '67 "valve" is just used to turn on the brake warning light if front or rear brake lines fail. You don't need it unless you're going to wire it to a light on your dash.
Old Jun 22, 2010 | 09:05 PM
63vetteguy's Avatar
63vetteguy
5th Gear
Thanks guys now i have another question. I cant not for the life of me figure out how to take my doors off. I know that sounds silly but i cant see any other bolts but the four on the hinges.
Old Jun 22, 2010 | 09:20 PM
TheSaint's Avatar
TheSaint
I am not going to use the prop valve because as you say its only for the warning light on a disc front disc rear set up.
But as i was told you need an adjustable one if you go for disc front and drums rear
Old Jun 22, 2010 | 09:26 PM
63Corvette's Avatar
63Corvette
Saint there is great info here. However no one has addressed pads, so my question is...."what is your proposed usage"???
If you are street driving, then go for it using the above information. However, if you are planning "hi-performance" usage.....(autocross, HPDE, or racing) then you will also need race pads (DT-70, PFC-01 or equal) AND cooling....(with stainless lines and Motul 600 fluid).
Old Jun 22, 2010 | 11:41 PM
wirenut's Avatar
wirenut
Default Parking brake cables and lever
If changing the rear to disc's will the parking brake cables and lever need to be changed?
To disc brakes without a conversion kit?
Old Jun 23, 2010 | 06:54 AM
gbvette62's Avatar
gbvette62
Yes, the 63 and 64 cables are year specific, and are different than the 65-82 set up.
Old Jun 23, 2010 | 07:16 AM
gbvette62's Avatar
gbvette62
Yes, the stock "proportioming valve" used from 67-82 is really just a glorified brake block, with the brake warning light switch installed.
I recommended using it because when used with the stock 67 master cylinder mounted bracket, 67 dual master cylinder and 67 brake line set; it makes a very clean appearing, simple to install, safe and stock appearing conversion. There are aftermarket dual master cylinder conversion kits, but I like the look of the stock 67 system and it can be done for less than the kits.
Old Jun 23, 2010 | 12:35 PM
TheSaint's Avatar
TheSaint
Its not "proposed usage" i ment a proportioning valve. sorry for not writing down the whole word
An adjustable proportioning valve if you go for discs front and drums rear
Sorry for shortening it to"prop valve" and dont write down the whole word
Thats was what i was trying to say
