Headlight problem
Old Jun 26, 2010 | 11:47 AM
FLY_LIFE's Avatar
FLY_LIFE
Default Headlight problem
Hi Guys,
Just wanted to know if there was a previous post on how to trouble shoot or repair the lazy driver side headlight on my 66. Takes a while to turn on while the passenger runs smooth.
Morris
Old Jun 26, 2010 | 11:55 AM
62Jeff's Avatar
62Jeff
Howdy,
Chances are the motor needs to be pulled out and cleaned, assuming there's no binding in the pivot mechanism of the headlight bucket itself.
Forum member BarryK has an excellent set of tech articles located at
http://lbfun.com/Corvette/Tech/vettetech.html
On that site is an article on rebuilding headlight motors.
http://www.lbfun.com/warehouse/tech_...%20Rebuild.pdf
It's found under the Body & Frame section of Barry's site.
The hardest part of the task is getting the motor out through the opening between the hood and the nose of the car. Removing the hood support and tilting the hood a little more forward (over-open) helps that situation. The motors are easy to take apart and clean. Getting the old hard grease out and replacing it with new lube helps.
Jeff
Old Jun 26, 2010 | 01:28 PM
67L36Driver's Avatar
67L36Driver
it is so easy it makes you want to file charges
against those guyz charging $128 per motor to rebuild them.
I think price has gone up since that was written.
The only thing I disagree with is turning the gear 180*. Just buy a new gear and run it 4-5 minutes each direction on the workbench. Seats the motor brushes.
Old Jun 26, 2010 | 02:18 PM
magicv8's Avatar
magicv8
First pull the retaining clip and disengage the motor assembly to see if the rotating headlamp assembly turns freely. If it doesn't, spray silicon lube into the pivots with a plastic straw spray nozzle.
To Headlight problem
