Console Cup/Junk Holder
Bill
on all counts. The drinks don't get in the way of shifting at all for me, even when one is in the front holder. Your arm is to the left side of the whole setup, and for me it sits far enough back that there's no interference. I have a 15" steering wheel that gives me a little more room & that might make some difference.
I'll report back when I get it.
if i had your money i'd burn mine....
Bill
You spray paint the underside of the clear plastic holder with your favorite color for a professional color change.
But in answer to where do you put stuff:
Coins go in your pants pocket.
Cell phone? Hate 'em, but when I do take it, it goes in the package tray until I want to call someone, I don't turn it on otherwise.
Beer can/bottle goes between your legs. If it is a can, dent the part of the can just under the opening so you can face the opening forward by feel, so when you stomp the gas, beer doesn't slop out all over your crotch. The dent in the can also helps your mouth locate the hole when you are cruising around at night so you don't pour beer down the front of your shirt. Old high school/college trick I figured out 30-35 years ago.
If you get into an impromptu drag race, you hand your beer to your buddy to hold, along with his beer.
This of course was back when having open containers in the car wasn't against the law.
Doug
Bill, where did you get the one you're using.
Thanks,
Dave
Advance Auto Parts
http://shop.advanceautoparts.com/web...7CGRP2013____#
http://shop.advanceautoparts.com/web...%7CGRP2013____
Bill
I also saw one similar to this that has a hole cut-out for the shifter and uses the are over the ashtray and in front of the clock. I'll look around and see if I can find it.
