Casting dates and broach marks
Old Jul 6, 2010 | 11:19 AM
remotecontroller's Avatar
remotecontroller
Default Casting dates and broach marks
Curious about casting dates and broach marks. Were blocks done on a Monday through Friday basis only, or did they do them on weekends as well? Were there also Weekdays that they didn't pour castings (Like on Fridays or anything)? If it makes a difference, I am wondering regarding Flint Motors between '57 and '67.
Also, at what point was the "longitudinal" block broaching stop? I have a '58 with the straight, front-to-back broach marks, but wondering when they stopped doing that and started using a circular milling machine process like shops use today.
Thanks!
Ken
Old Jul 6, 2010 | 12:25 PM
JohnZ's Avatar
JohnZ
Thanks!
Ken
The foundries normally poured on a six-day two-shift schedule, and kept the cupolas going on third shift and on Sundays. Saginaw supplied about 55,000 raw castings per day to Flint V-8.
Flint V-8 normally ran a six-day schedule (three shifts in Machining and two in Assembly); demand was enormous in the 50's and 60's. Flint V-8 and Tonawanda each built 5500 engines per day (300 per hour).
Flint V-8 and Tonawanda both used the huge horizontal block broaches as long as they built the Gen 1 small-blocks (through 1999 at Flint) and Mark IV big-blocks at Tonawanda. Neither plant ever built the "LS" series small-blocks - those engines come out of Romulus, Livonia, St. Catherines, and Silao, Mexico
Old Jul 6, 2010 | 06:25 PM
remotecontroller
JohnZ - cool info! thanks!!
Do you know what days Flint poured (was is Sunday that they were idle)? Wondering so if I ever see a Saturday casting date I don't assume it was tampered with...
Thanks again,
Ken
Old Jul 7, 2010 | 09:56 PM
JohnZ's Avatar
JohnZ
Thanks again,
Ken
Castings for Flint V-8 came from the Saginaw Foundry, which was generally idle on Sundays (unless demand required double overtime). Saturday casting dates and engine assembly dates were very common.
To Casting dates and broach marks
