Front coil over conversion
Old Jul 8, 2010 | 04:45 PM
TTop Tony's Avatar
TTop Tony
amazing! Such a simple design. Never see it before very nice.
Old Jul 8, 2010 | 06:21 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
Originally Posted by JLMICCA
Thanks for the responses guys. The pics better demonstrate my prior definitions of "semi" coilovers. As was noted above, one pathway is to trim the coils I have to get the desired ride height and then upgrade to shocks with adjustable valving. With this, I would consider the QA1 double vs single adjustable shocks. Again, for a street driven car, is there a significant advantage to the dual adjustable shocks?
There is no significant advantage to having double adjustable shocks for a street car. It is pretty much only needed if you are racing. A single adjustable shock will allow you to get the ride the way you want it. The only difference is a single adjusts both compression and extension at the same time, which is more than adequate for a street driven car.
Old Jul 9, 2010 | 12:58 AM
64 roach's Avatar
64 roach
van steel has a great looking kit, which I plan on buying some time soon, however I can not seem to find any feedback about how the system works maybe everyone who has it is out driving and enjoying it, you can find it listed under c3 performance on their site, very nice knowledgeable people, good luck Keith
Old Jul 10, 2010 | 01:55 PM
vt65's Avatar
vt65
Originally Posted by groovyjay
I've got Bilsteins all around. It's a kit made by a German company in Europe. YOu'll need to weld new brackets to your trailing arms.
Old picture of the mock up.
i like that, can you give me some part numbers please?
Old Jul 12, 2010 | 10:38 AM
JLMICCA's Avatar
JLMICCA
Grrovyjay,
Do you have part numbers or pics of the front coil over setup?
Old Jul 13, 2010 | 12:21 AM
JLMICCA's Avatar
JLMICCA
Just an update. I just received my September 2010 issue of Vette magazine and they have a tech article on the installation of the Speed Direct aluminum upper control arms and the Speed Direct Shark Bite front coilover kit which appears to have QA1 shocks with Speed Direct springs. You can probably find the article on the net. I have to tell you, the aluminum upper control arms look very stout. The only modification to the lower control arms was to open up the shock mount holes to 3/4 inch. As a bonus, they added a spreader bar. Next month, they will be installing the Speed Direct rear coil over kit (a truly unique design) so there are no road tests published to date.
Old Aug 11, 2010 | 04:18 PM
TeamTruett's Avatar
TeamTruett
I have the QA1 "semi-coilover" kit. The springs do not fit in the pocket on the frame well, the diameter is too small. The QA1 tech line guy gave me a really BS answer by explaining that "not all car frames will have the same size spring pocket even though they are the same model due to variables in the production process" (Funny, the stock springs fit perfectly} For the price I paid they should fit! I opted for the torrington bearing upgrade that makes adjusting easier.
I was also concerned with all the weight being on the bottom perch of the lower a-arm so I made some plates to spread the load for what its worth. Tech guy said its nothing to worry about, but based on the quality of his first answer I made some plates to mount in the lower a-arms. See pics:
http://www.flickr.com/photos/1209389...7603198130582/
Old Aug 12, 2010 | 11:21 AM
Speed Direct
TeamTruett, you have discovered the reason why we developed our own spring for the semi-coilovers. We discussed this problem with QA1 when it was first brought to light over a year ago and they had (and continue to have) no solution. The springs that they currently supply with their kit have an inside diameter of 3.5" yet the Corvette spring pocket requires a minimum I.D. of 3.7 to 3.8". Our springs fit the pocket correctly and they are shorter to give a full range of ride height adjustability. The QA1 springs are too tall to lower the ride height if so desired. Additionally, we have more spring rate options with our design.
Old Aug 12, 2010 | 01:04 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
What spring rates do you offer and are the springs available to fit the QA-1's?
Old Aug 12, 2010 | 02:53 PM
Speed Direct
Yes sir, our springs (with the adapter) are designed to work with the QA1 shocks. That is the kit we sell, QA1 shocks and our springs. We offer springs rates from 400 in/lbs to 750 in/lbs in 50 lb increments. If desired we can get up to 1000 in/lb springs.
Old Aug 12, 2010 | 05:00 PM
claysmoker's Avatar
claysmoker
I already have the shocks, so all I need is the springs. What is the adapter? I thought you had springs to fit the pocket in the car. What's the price and part # for 400 in.lb. springs?
Old Aug 12, 2010 | 06:16 PM
Speed Direct
The adapter is to fit the spring to the shock near the bottom at the ride height adjustment collar. The spring fits in the upper pocket just like the stock spring. The springs are $48.99 each (p/n sssy400) and the adapters are 59.98 for the pair (p/n 760-01000) for a total of $157.96 plus shipping.
The springs are at the bottom of the page. http://cmc.speeddirect.com/items.asp...&Pbm=&FromNav=
Old Aug 12, 2010 | 06:40 PM
  #33
claysmoker's Avatar
claysmoker
Are the adapters the same as come on the QA1 kit? If so, I need only the springs.
Thanks for the help.
Old Aug 12, 2010 | 09:28 PM
  #34
TeamTruett's Avatar
TeamTruett
Thanks, looks like Ill be calling you guys. The springs in the kit were 450s and are 10" tall. What's the price on similar springs and adapter plates shipped to 12533 NY Also the springs you have are blue, is that vinyl coated, powder coated or paint? I'll probably powder coat them.
Old Aug 12, 2010 | 10:13 PM
  #35
Tonytz06's Avatar
Tonytz06
I have front and rear coil over from Dpeed Direct, they fit perfect with no problems.
Old Aug 13, 2010 | 11:52 AM
  #36
Speed Direct
claysmoker, the adapters are still needed. They are not the same as the adjuster nuts included from QA1. They adapt the adjuster nuts to the spring diameter because our springs are not conical like the QA1 springs.
TeamTruett, all the springs are the same price so the above quote is accurate and shipping will be about $18 to NY. The springs are powder coated.
Please let me know if you have any further questions.
Old Aug 13, 2010 | 12:17 PM
  #37
claysmoker's Avatar
claysmoker
OK, I'll place the order now.
