Throwout bearing problem?
Old Jul 6, 2010 | 10:48 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Default Throwout bearing problem?
Centerforce clutch and throwout bearing. As the rpm goes up I'm getting a vibration in the pedal just as the throwout bearing hits the diaphragm. Depressing the pedal further, the vibration decreases to near nothing at the floor. At low cruise speeds you can just feel it as you go through the gears each time the pedal is depressed, but only right at the end of the free play.
I've never had one do this before. Any thoughts?
Oh, and the parts are all new.
Old Jul 6, 2010 | 11:02 PM
SledgeHammer 2.0's Avatar
SledgeHammer 2.0
I think it's the pressure plate, one or two uneven fingers that will even out as the clutch id depressed.
Just my .02
Old Jul 6, 2010 | 11:11 PM
claysmoker's Avatar
claysmoker
Just my .02
That was my thought as well, but since I had never run across it before, I figured someone here might have.
Old Jul 7, 2010 | 09:27 AM
MikeM's Avatar
MikeM
I have had it happen before and Pugly is right on the money. I didn't change the pressure plate because of the vibration. It didn't hurt anything in my case.
I suppose it could be a chunk out of the disc too. That could cause the fingers to be uneven.
Old Jul 7, 2010 | 11:06 AM
claysmoker's Avatar
claysmoker
Thanks Mike. I don't seem to have anything banging around in the bellhousing, so I doubt the disc has come apart. For now I will just take it easy and wait until this winter to pull it apart and have a look.
I appreciate your input.
Dave
Old Jul 7, 2010 | 12:44 PM
ptwohey's Avatar
ptwohey
Just in case it is not the fingers, you might try a PP inspection through the opening where the starter goes or anywhere else that will allow you to see the PP bolts.
It only happened to me once and the vibe was so bad I dropped the bell and found that I messed up when I torqued ( duh, tightened) the PP bolts. I don't know if they rotated after it was installed or if I just forgot to tighten the correctly but two bolts were loose enough to affect the fingers. After I correctly tightened and torqued the bolts and reassembled the mess, the vibe was gone.
Old Jul 7, 2010 | 01:55 PM
MikeM's Avatar
MikeM
Good point. A loose PP can cause uneven finger height.
If the OP has a mid year bellhousing, that's gonna' be a little tough to check those bolts.
Old Jul 7, 2010 | 06:05 PM
claysmoker's Avatar
claysmoker
I'm thinking that a loose PP is also going to make for a slipping clutch, which it doesn't. And yes, it is a midyear housing.
Old Jul 7, 2010 | 06:08 PM
6T7L71CPE's Avatar
6T7L71CPE
My LUK clutch does this. I only notice it if I engage the clutch slowly or if I don't have enough clearance. I just assumed I smacked the fingers installing the trans by myself.
To Throwout bearing problem?
