Gravity bleeding the brakes
Old Jul 7, 2010 | 12:55 AM
Early 63's Avatar
Early 63
Default Gravity bleeding the brakes
Just how long should this take?
I have a new 1964 style (Napa) m.c. Which I have bench bled very slowly with DOT 5 silicone fluid untill I can't get any more bubbles out and about 1/8" travel. Installed on my car with 4 new calipers(65-67 style) 2 new ss rear hard lines, 4 new rubber hoses. Completely dryed and cleaned out system. I opened all 6 bleeders and nothing after 3 hours. So I took line off of m.c. and blew air threw system, and air passed at all bleeders. Put back together and waited another 2 hours. Nothing. So I got anxious and closed all bleeders but one and very slowly manually bled untill all calipers were full, then tried to gravity bleed again. 2 hours- nothing. What the hell ?
Old Jul 7, 2010 | 01:36 AM
Astrodokk's Avatar
Astrodokk
I've done only two gravity bleeds and the last one I may not have waited long enough and I may still have air in the lines.
I'm not so sure about this but I was told to open just one bleeder at a time, not all at once. I started getting fluid out of each one in about 10 minutes and you have to monitor it so the MC won't run dry.
I think it took me about an hour for the whole job.
Since it pulls to the right when braking, I think there's still air in there, so I'm taking it to a brake shop to get it bled right and checked out. I'm going open track racing in three weeks and need good brakes.
Old Jul 7, 2010 | 02:00 AM
Uncle Ralphy's Avatar
Uncle Ralphy
I've got a 1973. 1 hour. 2 hours. Nothing. I ended up trying to gravity bleed my new MC overnight, still nothing. (Of course I did the bench work a few times prior to trying the gravity bleeds. Not a fun time if you've ever installed a master in one of those cars!)
Finally ended up brazing an air fitting onto an old cover and made my own pressure bleeder. Works like a charm.
Al
Old Jul 7, 2010 | 05:41 AM
mscaggs's Avatar
mscaggs
Uncle Ralphy,
Do you happen to have a picture of that cover you made?
Mike
Old Jul 7, 2010 | 06:55 AM
w1ctc's Avatar
w1ctc
The last time I changed my MC I had trouble getting a pedal. Out of frustration, I just started pumping the pedal. After about 50 strokes the pedal got hard and all was good. (Don't even go there with the use of certain word combination's in this post)
Old Jul 7, 2010 | 07:51 AM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
I gravity bled my lines after replacing all the brake lines. The calipers still had old fluid. The master cylinder was dry. I just filled the reservoir with dot 5 and opened the farthest bleeder. I had a hose connected to the bleeder going into a glass jar and waited for the dot 5 to come out. Took about 1 beer per wheel. (For the wheel closest to the master I really had to drink fast!) I never bench bled, and I have a good pedal. You have to make sure that the plunger in the master is not pushed in at all, because that will stop the flow.
Gerry
Old Jul 7, 2010 | 10:02 AM
wombvette's Avatar
wombvette
Have you ever syphoned gas out of a car? If you have you would understand, that thing ain't going to do anything until you get the air out of the lines. You have to do the pump method first first to get it flowing, and then gravity drain.
Old Jul 7, 2010 | 10:07 AM
lovevettes's Avatar
lovevettes
Default Brake bleeding
I my opinion the best way to bleed the brakes is by PRESSURE BLEEDING period.
I bench bled the master cyl.
I went to ACE hardware , bought the smallest [weed killer ] type sprayer,
Made a flat piece of aluminum with a tapped hole in it. to fit on top of the master cyl.
Put a 0 to 15 pressure guage on it .
Conected all together with brass fittings. I used a fitting under the metal about a half and inch long so that when I took off the metal plate the fluid would not over flow the master cyl. and drip all over the fire wall of the car.
Made a gasket out of neoprene.
used a "C" clamp to hold the flat piece of metal to the M. Cyl.
Put brake fluid in the container [sprayer] Pumped up the container with the pump on it.
Put between 5 to 10 lbs. of press. on system.
Opened up the fitting fartherest away. [ had tubing on it. and used a glass jar] Until I saw the fluid with no bubbles [ did the other three]
Was done in no time flat, went into the house told my wife I must have done something wrong because that bleeding was way too easy.
Never touched the system since .
There is a company that makes this very same sys. for about 80 bucks if you do not want to make one.
Old Jul 7, 2010 | 10:39 AM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
That would only be true if the brake line was routed higher than the master cylinder. In my car the master cylinder is the high point of the system so there's no need to siphon.
Gerry
Old Jul 7, 2010 | 10:51 AM
MikeM's Avatar
MikeM
I have found this to be very true. Not just on Corvettes, either.
I have also found that if you are working on a car with a brake distribution block, if you'll crack the line(s) at the block first, the fluid will drain to that point and then you can continue the gravity bleed.
I also know that what I just reported is not 100% consistent and I don't know why.
Old Jul 7, 2010 | 02:39 PM
wombvette's Avatar
wombvette
Gerry
I would guess you system is designed about like any other 66. You may get it flowing at some time, but I ain't got that much beer.
Old Jul 7, 2010 | 07:50 PM
Technite73's Avatar
Technite73
I did a frame off on my 66 and replaced every line, hose, caliper, master etc. All new all empty. I was amazed to see fluid running out in a manner of minutes.
Old Jul 7, 2010 | 08:38 PM
JohnZ's Avatar
JohnZ
Pressure bleed.
10-minute job.
Rock-hard pedal.
Priceless.
Old Jul 8, 2010 | 12:04 AM
Early 63's Avatar
Early 63
Gerry
This explanation is the only one that makes since right now. I'll have to look at the mc plunger rod. Maybe some how it's adjusted too close to the plunger and this keeps the fluid from passing. I'll be checking it out this weekend. Thanks. I'm trying my hardest not to shake up the DOT 5 so thats why I've opted for the gravity bleed.
Old Jul 8, 2010 | 01:02 AM
Canute's Avatar
Canute
Kind of wondering, with the '63/'64 single master plumbed the way it is, will it naturally always have a little more pressure at the front left wheel?
Old Jul 8, 2010 | 01:21 AM
Uncle Ralphy
Originally Posted by mscaggs
Uncle Ralphy,
Mike
Sorry, I don't. I gave it to a friend and it got passed on. I used an air hose coupler that I purchased for a few bucks. I drilled a hole to accept the threaded end of the coupler and brazed it to the cap, then attached my air hose to the other end, turned the pressure down to probably 8 psi and opened the air valve. I also filled in the air holes on the cap.
I had the LH rear bleeder open first I think (I followed the directions found on a the forum thread). I had to keep taking the cap off to refill.
If I had to do it over, I'd buy one of the pressure bleeders shown in JohnZ's post. They are only $60.00 or so, but would be easier to use.
Old Jul 8, 2010 | 01:53 AM
skids's Avatar
skids
Uncle Ralphy,
Mike
[IMG][/IMG]
Here's mine. About $15.00 total investment.
To Gravity bleeding the brakes
Old Jul 8, 2010 | 08:04 AM
67*427's Avatar
67*427
The new master cylinder makes me wonder.... some disc brake master cylinders have a small rubber check valve in them to prevent all the pressure from returning which is designed to hold the pads against the rotor. I wonder if your master cylinder has that? With no lines connected to it, there should be fluid dripping from the outlets. If not, I would check for that small valve. I can't remember where or how it was implemented but if you get no fluid dripping, I don't think you will get there by gravity bleeding.
BTW, when I gravity bled mine, I had fluid at the caliper(s) in just a few minutes.
Hope that helps,
Steve
Old Jul 8, 2010 | 08:37 AM
mashinter's Avatar
mashinter
I know the guys in the GM shop used gravity bleed back in the day. I'm assuming (haven't played with brakes for years...make that decades) that all the fluid for a gravity bleed flows through the compensating port, which is tiny. Guess that's why it takes so long? Anyway, check to make sure your compensating port is open.
Old Jul 8, 2010 | 09:03 AM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
In a hydraulic system, the pressure is uniform everywhere. Whatever pressure exists at the LF will (assuming a single circuit master cylinder) also exist at the RF, LR, and RR.
Jim
