spark plugs
Old Jul 8, 2010 | 10:22 AM
vett64's Avatar
vett64
Default spark plugs
what spark plugs should be used for a 1964 fuelie?
Old Jul 8, 2010 | 12:00 PM
MikeM's Avatar
MikeM
Use AC R45 or equivalent.
Or, you can try AC R45S. It's been reported on some engines, the extended tip of the "S" plug will hit the piston. I run the "S" plug in an engine similar to yours without any problem.
Old Jul 8, 2010 | 02:11 PM
Ironcross's Avatar
Ironcross
The 'S' suffix problem I had was on my 315 hp 61 piece. You should not have any problems with a 64 FI piece. Do not use a colder heat range than the 45....You may be prompted to use a R43 as the correct plug, it`s not! Unless racing it has a tendency fuel foul with normal or low speed driving.....But if you want experience in changing spark plugs with a FI Vette with all that protective crap and air cleaner use something else than Mike recommended ....
welcome to the FI world....{hint} they need to be driven and not set around in a garage or on a trailer
Old Jul 8, 2010 | 02:18 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i use an Autolite #86, it's equivalent to the AC 45.
#8 cylinder, probably about 13K miles on this plug
Bill
Old Jul 8, 2010 | 04:12 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Bill
Some say the Autolite is the best made plug going...
Old Jul 8, 2010 | 07:32 PM
vett64's Avatar
vett64
Thanks for all your replies. We put the AC R45S in today and back off the fuel meter some to lean, and she runs much better!!!
Sam
Old Jul 8, 2010 | 07:44 PM
aaronz28's Avatar
aaronz28
funny... coming from the guy who puts 13 miles on his 62 FI every year.... thats 13 miles worth of backing it out and back into a Garage
A
Old Jul 8, 2010 | 08:12 PM
Ironcross's Avatar
Ironcross
A
all right smart ***....you forget I have the solenoid under the dog house...so I dont count.......
stop around AA..oh did you know there is a 'Michigan Ave Cruise Saturday?
To spark plugs
