Battery Drained...
Old Jul 9, 2010 | 11:12 AM
Eugenio's Avatar
Eugenio
Default Battery Drained...
I have a 67 427 and recently I found the car battery drained for no reason. I drove the car all week and all of a suuden it doesn't start.
I recently replaced the dash harness and I have checked all the fuses, the glove box light, voltage regulator and the alternator and they all show good.
I just put in a new battery yesterday and as I started the car the ammeter showed a full charged battery but a few seconds later I could see the needle on the ammeter moving irratically and moving towards the negative zone. There is something that draining the battery at a fast pace.
Can anyone help..this is driving me crazy...
Greatly appreciated..
Old Jul 9, 2010 | 12:44 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Check all of your connections first. My regulator plug comes loose sometimes. Also double check your battery ground connection.The quick drop sounds like a connection loss. I am sure more knowledgable folks will chime in.
Old Jul 9, 2010 | 02:00 PM
JohnZ's Avatar
JohnZ
Based on the erratic needle movement, I'd also suspect a voltage regulator problem, or a failed diode in the alternator.
Make sure the terminals at both ends of both battery cables are clean, shiny, and tight, and the same with the screw-terminal wire connections at the horn relay (disconnect the battery ground cable while cleaning/checking connections). Could also be the battery cables themselves (too small, corroded inside the jacket, etc.).
To Battery Drained...
