Electrical Issues
Old Jul 17, 2010 | 12:46 PM
cliffc8488's Avatar
cliffc8488
7th Gear
Default Electrical Issues
When I turn on the directionals or step on the brake the fuel gauge goes wacky. Bad ground?
Do vettes use the frame as ground or is there a ground bus?
Old Jul 17, 2010 | 02:09 PM
62Jeff's Avatar
62Jeff
What year? If you have a 62 or older, then yes that is typical, and can be solved by adding a dedicated ground wire from the fuel sending unit to the frame.
Old Jul 17, 2010 | 02:31 PM
Donald #31176's Avatar
Donald #31176
http://www.rarecorvettes.com/RARE/DancingGasGuage.html
Old Jul 17, 2010 | 06:08 PM
cliffc8488's Avatar
cliffc8488
7th Gear
Yes, it's a 62. Thanks for the info.
Old Jul 17, 2010 | 06:35 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Here is the article by John Hinkley on this topic....so you have an extra resource.
File Type: pdf
Old Jul 18, 2010 | 09:04 PM
cliffc8488's Avatar
cliffc8488
7th Gear
Soldered a wire to the sending unit and ran it to the chassis. Gauge is stable now.
The other problem I'm having is the left directional indicator lights when I turn on the parking lights. Any ideas?
Old Jul 19, 2010 | 05:25 PM
magicv8's Avatar
magicv8
it's probably a bad ground at the front or rear sockets
if the indicator works otherwise (blinks when turn signal lever is used) it may be the switch
otherwise there is a panel lamp plugged into the cluster hole for the turn signal indicator
To Electrical Issues
