Electrical glitch
Old Jul 20, 2010 | 02:24 PM
tko44140's Avatar
tko44140
Default Electrical glitch
i recently restored my 65 convertible and after installing the radio tried the antenna switch. the up goes down and the down goes up. what could cause that if all connectors are "one way" and have not been disassembled? thanks in advance, tom
Old Jul 20, 2010 | 03:06 PM
magicv8's Avatar
magicv8
is the switch installed up side down?
Old Jul 20, 2010 | 03:26 PM
66jack's Avatar
66jack
The plug at the rear CANNOT be turned because it only plugs in one way.
jack
Old Jul 20, 2010 | 03:55 PM
LB66383's Avatar
LB66383
Maybe you hooked the battery up backwards? Just kidding!!
Is this the original switch or a replacement? What about the antenna end of the harness? Can that be reversed? That's a legit question, I've never paid attention to my antenna.....it's never worked and I don't really care.
Old Jul 20, 2010 | 08:28 PM
tko44140's Avatar
tko44140
its been a couple of months since i hooked up the antenna but as i recall the plug connector is "one way" that is, the leads are in a "t" formation. to get to it i would need to remove the spare tire tub and the muffler
Old Jul 20, 2010 | 08:57 PM
62Jeff's Avatar
62Jeff
This was the case with my 65. When I first got the car the switch worked "backwards". Then I realized that the switch had been installed upside down. I removed the mounting screws, rotated 180 and remounted.
Old Jul 20, 2010 | 09:14 PM
tko44140's Avatar
tko44140
if i remove the switch from the panel and rotate it the labeling is on the back side
Old Jul 20, 2010 | 09:15 PM
62Jeff's Avatar
62Jeff
Ok, then it's not upside down. On mine, I didn't know I had labeling until I rotated it.
Old Jul 21, 2010 | 12:08 AM
IBLather's Avatar
IBLather
is this the reproduction antenna switch?
Irv
Old Jul 21, 2010 | 09:25 AM
tko44140's Avatar
tko44140
it is an original switch
Old Jul 21, 2010 | 09:47 AM
chet b's Avatar
chet b
Have you replaced the antenna with a new one? The 66 coupe I owned and replaced the antenna on was wired wrong. It was a reproduction antenna from a well known vendor.
Old Jul 21, 2010 | 11:22 AM
magicv8's Avatar
magicv8
is it mounted up side down?
Old Jul 21, 2010 | 12:28 PM
tko44140's Avatar
tko44140
it is the original antenna that has been rebuilt but not rewired
To Electrical glitch
