1963 conv.
Old Jul 28, 2010 | 07:53 PM
rick charles's Avatar
rick charles
Default 1963 conv.
Is the exterior or outer windshield trim on a 1963 convertable one year only ?
Old Jul 28, 2010 | 09:29 PM
project63's Avatar
project63
Only the lower center piece. The rest are common thru 67.
tc
Old Jul 29, 2010 | 05:40 PM
rick charles
Default 1963 lower stainless trim
so what are the differences between the 1963 & 1964 lower stainless for convertables ?
Old Jul 30, 2010 | 10:08 AM
rick charles
Default 1963 conv
A little help from all you guru's...........................
Old Jul 31, 2010 | 06:20 PM
rick charles
Default 1963
are you serious , no body can help ??????????????????????
Old Aug 1, 2010 | 02:35 AM
rene-paul's Avatar
rene-paul
The 63 lower stainless moulding has a different profile than the 64. Reason being is the 63 moulding attatches to clips that clip over the pinch welded windshield frame underneath the windshield rubber weatherstrip. On 64 and up the lower moulding attatches to clips that are screwed into the pinch welded windshield frame outside of the rubber weatherstrip. Almost. Thus the smaller profile on the 64 and up. Ref the 63 and 64 AIM. Hope this helps.
Brgds
rene
Old Aug 1, 2010 | 09:50 AM
rick charles
Default 1963
Thank you for your help.............
Old Aug 1, 2010 | 11:00 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
I had my 63 convertible painted a few years ago. Didn't even mess with trying to remove the lower SS trim. Left it on, and masked around it.
I knew that the mounting was different. Rene-paul has explained the difference. Thank you.
Chuck
To 1963 conv.
