DynoSim5
What exhaust model do you use for pre-62 factory manifold and pipes? The "stock plus muffler and cats" seems a bit too restrictive" but would you call this "H.P. manifold and muffler w/o cat"? That seems to stretch it a bit.
Also, how would you classify the Performer EPS manifold? "High flow dual plane", or "High torque dual plane"?
From most of the tests I've seen the Performer RPM Airgap seems to be the highest flowing dual plane and would be a "Max flow dual plane"?
I'm fairly disappointed at the minimal options available for both of these systems but what can you expect for $100?
Thanks in advance for any suggestions you may have!
DT
