Ignition switch ACC position
Old Aug 13, 2010 | 02:26 PM
amtronic1's Avatar
amtronic1
Default Ignition switch ACC position
Being generous I let my wife drive my 66 convertible. When she parked it, she removed the key but the key was in the ACC position. I didn't notice it for 4 days and naturally the battery is dead. So on to the questions:
Should the key be removeable in the ACC position?
What circuits are energized with the key in the ACC positon?
The battery has been on the charger for 4 hours, it's settled at 11.4V which tells me it has a dead cell. To be expected I believe.
Old Aug 13, 2010 | 02:34 PM
...Roger...'s Avatar
...Roger...
Heater , radio , wipers , turn signals and voltage reg I believe.
I think the key does come out but won't turn back beyond off.
Old Aug 13, 2010 | 02:39 PM
Bill Wilhelm's Avatar
Bill Wilhelm
In 1966 the key should only come out in the off position. Key or switch (or both) may be worn. Bill
Old Aug 13, 2010 | 02:44 PM
amtronic1's Avatar
amtronic1
Many thanks!@!
Old Aug 13, 2010 | 02:50 PM
Trkdrvr's Avatar
Trkdrvr
Default acc. position
I have a 66 and my key does come out in the accessory position, and the battery goes go dead overnight, and that's with nothing on or in use. Unfortunately, it has happened to me twice now, but was able to fully recharge battery. Bad design! Any body have an idea to prevent this other than being more careful?
Chuck
Old Aug 13, 2010 | 03:24 PM
mdz06vetter's Avatar
mdz06vetter
St. Jude Donor '05-'10-'11-'12-'13-'14-'15
not a bad design! repair the switch, that is the problem as it is worn
Old Aug 13, 2010 | 03:47 PM
Ron Miller's Avatar
Ron Miller
My '66 key is removable not only in the ACC position, but also in the OFF and RUN positions!
I'm gonna get around to replacing the ignition tumbler one of these days, along with the door locks which still work OK. But, I want them to all be keyed alike.
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
What's an ACC position?
Tom Parsons
Old Aug 13, 2010 | 08:43 PM
JoeCool66's Avatar
JoeCool66
Yep, same here, and I find it handy to pull the key and unlock my glove box when I'm driving along...
Joe
Old Aug 13, 2010 | 08:52 PM
65hihp's Avatar
65hihp
my old original keys both pulled out of ign in On and ACC, as well as Off. They were well worn.
I did not have my knockouts so I pulled my ign switch and obtained the numbers off it, as well as that of the tumbler in the glovebox door lock. Sent the key numbers to Pete Lindahl in NM, and he returned two sets of new keys to me, along with all the requisite knockouts.
The new keys do not pull out of ign when they are not supposed to.
So, I have good fresh keys for judging when I want to do that, and old worn keys to pull out of ignition and play with while I am driving when I want to do that.....
write me if you want info on Pete. He's the man when it comes to worn out keys.
Old Aug 13, 2010 | 09:41 PM
Ron Miller's Avatar
Ron Miller
Pete is associated with the New Mexico chapter of the NCRS, you can find information and his phone number at http://www.ncrsnm.com/classifieds.html
Old Aug 14, 2010 | 01:23 PM
JohnZ's Avatar
JohnZ
Everything except power to the coil.
Old Aug 14, 2010 | 02:37 PM
Trkdrvr's Avatar
Trkdrvr
john z; what actually draws power? Every thing off and still runs down battery overnight. I have igniter ignition, lights off, radio off and key in acc. position. help
Old Aug 14, 2010 | 02:57 PM
Ron Miller's Avatar
Ron Miller
Start by pulling fuses at the fuse block one at a time, putting a small test light across the two terminals of the fuse block connections. Any circuit drawing current should have enough current flow to make the bulb glow, at least slightly. (Don't forget to hold the interior light button in at the door when checking that circuit! )
Could also be a defective diode in the alternator, defective regulator. Unhook those one at a time, see if the problem persists.
That'll be a start, anyhow! (Key in the ACC position?? Why?? Put it in the OFF position, see if anything changes)
Old Aug 15, 2010 | 03:09 PM
JohnZ's Avatar
JohnZ
Is your glove box light turning off? That's a frequent cause of ignition-off draw. If that's OK, it's probably the alternator (bad diode).
Do NOT leave the car with the key in the "ACC" position; that feeds power to everything in the car that might be turned on. The glove box light is fed directly from the battery (it's hot all the time), so it works regardless of what position the key is in.
Old Aug 16, 2010 | 06:21 PM
TX63CONV's Avatar
TX63CONV
I have a similar issue with my battery going dead (even in the off position) if I leave it off the charger for several days.
My bulb is gone in my glove box so no light but not sure about the connection. Would this have enough draw to kill a battery after several days?
Old Aug 16, 2010 | 08:27 PM
Avispa's Avatar
Avispa
Chuck
You'll just have to replace the ignition lock cylinder. When they get a little worn the key comes out in any position.
Old Aug 17, 2010 | 12:09 AM
Sxrxrnr's Avatar
Sxrxrnr
Tom Parsons
Old Aug 17, 2010 | 12:53 AM
Sxrxrnr's Avatar
Sxrxrnr
Could be your clock trying to wind itself. If it should hang up while doing so, it will act as a low level short and run a battery down in a few days.
To Ignition switch ACC position
