Threaded Crankshaft
Old Aug 19, 2010 | 06:15 PM
TX63CONV's Avatar
TX63CONV
Default Threaded Crankshaft
Need some solutions on the threads of my crankshaft snout that appear to be reamed out.
Original crank from an 870 block...I didnt notice how bad until I picked it up from the machine shop.
I've updated this thread with some pics....
The threads are wallowed out to about a depth of 3/8 however the 7/16 balancer bolt I picked up from summit will not start.
(a) is 7/16th the correct thread size? 3/8 bolt wont start either.
(b) if I am going to drill further into the crank for a 7/16 , how far should i drill to ensure enough threads?
(c) what size bit should I use prior to taping for 7/16?
(d) any issues with my plan?
Old Aug 19, 2010 | 06:17 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
even a helicoil would probably require redrilling and tapping; so i would just drill and tap the next larger size.
Bill
Old Aug 19, 2010 | 06:42 PM
Nev Williams's Avatar
Nev Williams
Originally Posted by TX63CONV
Need some solutions on the threads of my crankshaft snout that appear to be reamed out. I am pretty sure running a tap through them is not going to work.
Should I tap to the next size? Any other solution?
Derek,
This is what you need - KeySerts.
Look here for info
http://www.afsrecoil.net/uploads/pdf...s_sizes_en.pdf
Also here is a more comprhensive catalog
http://mdmetric.com/pdf/keysert.pdf
They are just the ticket for filling in holes that have become to large for a helicoil.
Hope this helps
Neville
Old Aug 20, 2010 | 09:58 AM
Coves4me's Avatar
Coves4me
Derek,
I drilled out my crankshaft on the 59 with a right angle air drill, 5 or 6 carbon steel drill bits, plenty of patience, measuring and with the engine in the car. Once the hole was drilled, I then used a tap, plenty of oil and again a large amount of patience to finish the crank snout. I installed a Summit racing crank bolt and washer kit to hold the balancer on. If you have to go to a larger diameter bolt to make it work, I would go to Elliott's hardware and match up the bolt you want to use with the proper drill tap so it will work properly. You can also match up a retention washer at the same time. Good luck, Mark
Old Aug 20, 2010 | 10:06 AM
TX63CONV's Avatar
TX63CONV
Thanks everyone, thats what I was thinking....since the block is on the stand, it should be a ton easier....
Old Aug 20, 2010 | 10:28 AM
knockbill's Avatar
knockbill
sometimes a metric tap will work in an enlarged hole with out re-drilling,,,
i drilled mine deeper, while the engine was on teh stand, & used a longer, standard size bolt...
it tightened up good and held teh proper torque.....
Old Oct 24, 2010 | 09:36 PM
TX63CONV's Avatar
TX63CONV
Bill
See my first pic, I dont think this will work as the hole appears conical with max width greater than 1/2 inch
Old Oct 24, 2010 | 09:55 PM
JohnZ's Avatar
JohnZ
Based on the first photo, that crank never had a bolt in it to begin with; the bolt threads are 7/16"-20, and only the SHP engine cranks were drilled and tapped for a bolt; the others just had a press-on balancer. What you're looking at in the photo is the conical machining center.
Old Oct 24, 2010 | 10:01 PM
TX63CONV's Avatar
TX63CONV
Thanks John. That should have occurred to me since this was a non-corvette block.
Should I tap the crank anyway or just leave and press the balancer on?
Old Oct 24, 2010 | 10:14 PM
Glasshole's Avatar
Glasshole
If it's not the larger finned SHP balancer then just press it on.....
Old Oct 24, 2010 | 11:01 PM
TX63CONV's Avatar
TX63CONV
Its not the finned but its an 8inch....
Old Oct 24, 2010 | 11:51 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
I went through the same thing when I built my motor. The 250-300 hp cranks out of the Vette 2870 blocks were not drilled and they had the 6 inch press on bal.
I didn't want to drill my crank. I just pressed (pounded) on my 8 inch shp balancer.
I have had no issues with it moving. I had to chase an oil leak. So when I used the puller,it came loose with the proper snap. So I know it stayed seated. That and straight belts and pulleys.
Some may not agree.. I do keep an eye on it.
Old Oct 25, 2010 | 12:04 AM
MiguelsC2's Avatar
MiguelsC2
I will add, since your crank is out of the car. I would take it to a machine shop and have it properly drilled and tapped. IMHO no reason not to.
If your balancer is GM and has "made in Canada" ? It's the SHP replacement. Would be nice to have the fins for cooling. But I didn't want to spring the extra bucks for the fins. Since they stopped the fins,I guess that means they weren't needed.
Old Oct 25, 2010 | 05:24 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
I don't know how you would "press it on". I had to use a sledge hammer and piece of pipe to "press" my 63 balancer on.
Old Oct 25, 2010 | 06:11 AM
aworks's Avatar
aworks
There was never a bolt there. Most 327s where just pressed on. Drill and tap it and put a bolt in. It's very cheap insurance.
Old Oct 25, 2010 | 01:13 PM
MiguelsC2's Avatar
MiguelsC2
They may have had a press at the factory. But in the garage,they are tapped on. Since there aren't threads, a press or pull on device can't be used. To the best of my knowledge.
Old Oct 25, 2010 | 01:31 PM
midyearvette's Avatar
midyearvette
......3/8 bit and a 7/16 20 tap....easy enough to do yourself
Old Oct 25, 2010 | 02:22 PM
john5801's Avatar
john5801
Default crank shaft
refer to john z's thread above..
if the crank shaft is out of the motor, this would be an opportune time,and i would suggest, that you take it to a good machine shop and have it checked for balance, journals, etc, AND have them drill it out for the crank bolt if you decide to go that way, rather than pressing the balancer on...
btw, the mr.gasket 7/16'-20 nf crank bolt is correct, and takes 23/64"drill to prep it for the 7/16" threading.
also, check youre timing cover to see if --the timing tab--is placed for the 8" balancer, or closer to the crank shaft for the 6" or 6 1/2" balancer..either will work fine....imo..
hope this helps..
good luck
john
Old Oct 25, 2010 | 02:32 PM
TX63CONV's Avatar
TX63CONV
Thanks everyone for the responses.....
To Threaded Crankshaft
