Horn Button
Old Aug 22, 2010 | 08:20 PM
woodsdesign's Avatar
woodsdesign
Default Horn Button
Anyone have a procedure, or trick, for installing the horn button so it works when pressing anywhere on the button. I had it working good then I installed a new turn signal switch. Now the switch works great but the horn only blows when I press the lower right corner of the button. About 4 o'clock. I have a 65 with tele. It is an original horn button.
Larry
Old Aug 22, 2010 | 11:16 PM
fwillison's Avatar
fwillison
I have the same problem
hopefully someone has some helpful tips
Old Aug 23, 2010 | 02:25 AM
65 Pro Vette's Avatar
65 Pro Vette
C2 of Year Finalist (appearance mods) 2019
The problem is most times the horn contact under the horn button. take it out, fold a pc of fine sandpaper slide it between the contact flange (where it mounts to the steering column) and the button mount side, do the same on all 3 sides, the steel must make good contact on all 3 spots so it can make a good ground
Old Aug 23, 2010 | 09:17 AM
ricks327's Avatar
ricks327
That's what I did to correct the problem.
Rick
Old Aug 23, 2010 | 03:49 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
that works for a while. they are cheep enough were I would buy a new one.
To Horn Button
