Hurst shifter
Old Aug 24, 2010 | 06:00 PM
Brumbach's Avatar
Brumbach
Default Hurst shifter
I seem to recall forum discussions of using a muncie look-alike hurst shifter. Can anyone point me to the source of supply and part number? Thanks,
Old Aug 24, 2010 | 06:54 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
just about all of the parts vendors have them; check their websites
Bill
Old Aug 24, 2010 | 07:00 PM
66jack's Avatar
66jack
Here are the parts you want or just call hurst
http://www.hurst-shifters.com/hurst-...INSTALL-KIT_11
http://www.hurst-shifters.com/hurst-...LUS-SHIFTER_35
66jack
Old Aug 24, 2010 | 07:39 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
the look-a-like C2 shift lever that bolts directly to the Hurst shifter is available at most aftermarket Corvette specialists. Seek and ye shall find.
Old Aug 24, 2010 | 07:43 PM
1snake's Avatar
1snake
Don't know about the C-2 Hurst shifters with the replacement/stock looking handle but on the C-1's using that set-up there is an obvious difference. The handle is too tall and just doesn't look right.
Jim
Old Aug 24, 2010 | 10:03 PM
GUSTO14's Avatar
GUSTO14
William,
ZIP has this one for your '65...64-67 4-spd Bolt-On Shifter Shaft
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={adfe4662-bd4b-4521-9a99-bbaa868ab57e}&gid={1c173ee9-4f27-4626-86a6-9132de3cc65e}&GroupName=OE-style+Shifter+Shafts&pname=64-67+4-spd+Bolt-On+Shifter+Shaft&Referer=&Alias=&ptct=SG R-SR&CTitle=&
The reverse lock out is spring loaded like the original, but does not actually lock reverse out.
Good luck... GUSTO
Old Aug 24, 2010 | 10:12 PM
tach drive 61's Avatar
tach drive 61
Jim
I have a thread about c1 with a boot problem fitting the hurst shifter this may work .could be shortened for a C 1
Old Aug 24, 2010 | 10:16 PM
tach drive 61
Originally Posted by GUSTO14
William,
Good luck... GUSTO
how about a c1 alterative shifter for the hurst, this one would bolt up and need to be modified /shortened,could be done !
Old Aug 25, 2010 | 10:03 AM
wmf62's Avatar
wmf62
St. Jude Donor '07
Bill
Old Aug 25, 2010 | 12:49 PM
Donald #31176's Avatar
Donald #31176
Try using the repro original style boot with the wire reinforcement. Im using the old style Hurst shifter in a 62 and the fit is perfect.
Old Aug 25, 2010 | 06:41 PM
tach drive 61
Originally Posted by wmf62
59-62
Bill
bill please tell me more about this shifter and where I can order one ,is is a bolt on hurst shifter .looks just right !
Old Aug 25, 2010 | 07:20 PM
Kerrmudgeon
So what you guys are saying is that the repro version of the original with the metal spring around the hole will allow it to stretch and fit snug over a rectange Hurst shifter. Right? Hope so because I really like the way it doesn't stick up like other boots.....looks neat and tidy.
Old Aug 26, 2010 | 01:08 PM
JohnZ's Avatar
JohnZ
If your Hurst shifter has a handle attached with two bolts, the "look-alike" reproduction levers shown above will bolt right on. If your existing Hurst is an older one where the lever is welded on, they won't.
To Hurst shifter
