Brakes....HELP?????
Old Aug 26, 2010 | 06:50 PM
6redvette6's Avatar
6redvette6
Default Brakes....HELP?????
66 Convertible big block. Loaded car on trailer for new top installation.
Noticed once on trailer that there was a puddle under driver side front tire.
Thinking I had blown a brake line? However, today I took front tire off
thinking I could find the problem. Brake line appears OK. Had my son
pump brakes while under car. No leaking brake fluid at all? Open master cylinder and it's about 3/4 full! Car has been sitting for about 2 weeks since first noticed problem.....no fluid on garage floor at all.
I also thought that maybe loading on trailer at an incline fluid spilled out of master cylinder.......again no evidence of spilled fluid down side of MC.
Any suggestions short of having a brake shop look at the problem?
Go easy on me I am a rookie at this. Thanks
Old Aug 26, 2010 | 07:16 PM
Bill Irwin's Avatar
Bill Irwin
Are you sure what you saw was brake fluid? Bill
Old Aug 26, 2010 | 07:19 PM
6redvette6's Avatar
6redvette6
Bill, thanks for asking......but yes it was brake fluid. I forgot to mention that the brake pedal has gone soft.
Old Aug 26, 2010 | 07:22 PM
66jack's Avatar
66jack
Check the caliper....the seals could be going out where the two halves are put together..
jack
Old Aug 26, 2010 | 07:32 PM
jdk971's Avatar
jdk971
are you sure it was not there before you pulled up on the trailer. good luck jim
Old Aug 26, 2010 | 08:07 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
jack
Wouldn't there be obvious signs all over the pads,disk and caliper?
Old Aug 26, 2010 | 08:11 PM
midyearvette's Avatar
midyearvette
jack
...happens sometime after a long sit with no brake action...best to pump them up occasionally, should be stains on the back side of the rim and tire for an in board a caliper leak .....
Old Aug 29, 2010 | 07:19 PM
6redvette6's Avatar
6redvette6
OK guys here is a follow up question. Drove car around block, came back
and found another puddle of brake fluid under the left front tire..
This time I found fluid on the inside of the tire?
Am I looking at a faulty caliper or possible blown brake line??
Help please!!!!!
Old Aug 29, 2010 | 08:22 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Brake fluid leak
It's more than likely a leaking caliper. Are the calipers S/S sleeved ??? If not, at least replacing that one is in order. Most auto parts houses have S/S sleeved calipers available, and they usually come with a lifetime warranty. I put 4 of them on my car in 1989, and haven't had a problem since.
RON
To Brakes....HELP?????
By Michael S. Palmer | 2026-06-03 11:00:24
