396 Vette
There are a number of things to look for that will identify an original 1965 396 car. Many of these differences have been discussed before and may be in the archives or the FAQ at the beginning of the C2 Forum Page. We went through this a few months back for another forum member. Also, an NCRS Judging Manual will list these differences.
Is this a car you are trying to buy?? If you can't find this information and really need it, let us know and we can re-post it for you here.
I would start with providing all the info listed on the VIN Tag and TRIM Tag. We can then go from there.
Larry
See if you can find the Feb. '65 issue of Hot Rod magazine at your local library. The new 396 was the front page article. "The high performance engine Chevy fans have been waiting for is here!"
- The battery is located on the left side (same as A/C cars) and the access panel is held on with 7 bolts (I think)
- Oil Pressure gauge should be 0-80 psi
- Tach has a redline of 6500
- Differential uses saddle caps as opposed to u-bolts to hold the u-joints in place - If you can, check number on the diff housing as the number (stamped) will tell you more
- There should be a rear sway bar mounted
- Front sway bar is larger diameter
- Front coil spring is .600" wire diameter (assuming they've never been changed) and 17" free height (you won't be able to check that).
- Block should be casting number 3855692
- Heads should be 208 castings
- Intake should be 3866963
- Exhaust Manifolds should be 3856301/3856302
For reference, the serial number on my '65 396 coupe was 113934 and was built late March and yes, it was an early build.
Do you have Nolands book? If not, get it as it is worth its' weight in gold the information that is there.
Hope this helps.....
Eric
This is great info. Unfortunately, the original 396 blew up a ways back but has a rebuilt 396 now. I'm printing this out and taking it along with me to hopefully verify the car, just to see if it was, indeed, a big blocker to start with! Excellent!
See ID a 65 396 car
Here are a couple more details:
- Front sway bar measures 15/16"
- Rear sway bar 7/16"
- Rear spring 7-leaf
Good luck!
See ID a 65 396 car
Good luck!
Also the clutch rod, where it connects to clutch swing pedal is app.1/2 inch from where s.b. are connected seems to be different clutch swing arm I compared one of mine to a s.b. 65 i was restoring at the same time. There is a differance in the arms. Thanks 66racer
also the throttle linkage arm is bent differently on the 65 bb
look for a battery cable bracket just below the heater core which is on the 66 but i don't know about the 65....
Thanks for the clarification; I did not know that. I was thinking (danger!) that the F40 suspension was a mandatory 396 option, i.e., heavier springs for the additional weight.
LNJ
Dave
Dave
Is your 65 a 396 car? We are making a list so we can exchange info, parts, etc.
I don't think it is , built too early Nov-7-64. but my car does have the filled volt-reg. holes in the lower front area of the passager fender. This is a non-air car that someone added aftermarket air, so maybe that person filled the holes and added the cable clips? and I checked last night 7 cable clips across the firewall. Most of the cable clips have solid type pop rivets and a couple have the pop rivet with the hole in the center. Car also has holes filled under the fender cross flags and 80 psi oil gauge.
Dave
Best, Raymond
