dumb question
Old Aug 27, 2010 | 08:23 PM
360guy's Avatar
360guy
Default dumb question
My C2 has a NOM 350 with a lot of the original parts, heads Carter AFB etc. It has an after market Edlebrock manifold and chrome valve covers. There is a line with a PVC valve plugged into one of the valve covers. Seems as if the original owner is trying to run modern technology with some original parts. I want to remove the valve covers and put original covers on and just plug a screw into the manifold where the pvc line is run to the valve cover. Any thoughts?
Old Aug 27, 2010 | 09:09 PM
66jack's Avatar
66jack
You cannot do that.
Your engine needs to breath.
Keep it as is.
66jack
Old Aug 27, 2010 | 09:17 PM
360guy's Avatar
360guy
If I want to replace the valve covers, what should I do then?
Old Aug 27, 2010 | 09:23 PM
66jack's Avatar
66jack
you still need a pcv valve, no matter what you do with the 350.
where do you fill the engine with oil?
jack
Old Aug 28, 2010 | 05:15 AM
360guy's Avatar
360guy
Currently, the valve covers have a filler on them, which I have a vented oil cap on. There is also a filler tube that comes out of the front of the intake which I have capped. The engine block is a 1969.
Old Aug 28, 2010 | 08:31 AM
chris ritchie's Avatar
chris ritchie
Do a search on "pcv." This subject has been extensively discussed. Many people will tell you what to do. But you need to understand the issue and satisfy yourself.
Old Aug 28, 2010 | 08:47 AM
66jack's Avatar
66jack
Buy the correct oil filler that has pcv connection on it, make the connection at this point and keep the hose going to the base of the carb.
Then you can put on some vet valve covers or what ever you want.
Corvette Central has the ones you need.
Part#'s 302114,302107 or 302105
Other venders as well.
jack
Old Aug 28, 2010 | 12:12 PM
JohnZ's Avatar
JohnZ
Take a look at this.
File Type: pdf
Old Aug 28, 2010 | 05:52 PM
360guy's Avatar
360guy
Thanks a lot for the quick response guys. It never fails to amaze me how quickly you can get information on here. Even if it is a "dumb question"
To dumb question
