Need a jack
Old Aug 29, 2010 | 05:28 PM
rick66's Avatar
rick66
Default Need a jack
Went to Carlisle looking for a jack for my 1966. Came back empty handed. It doesn't have to be a 1966. I just want a jack that will work with the lug wrench. Before I post over at the "wanted to buy" area, will all midyear jacks operate with a my 1966 lug wrench?
Old Aug 29, 2010 | 08:52 PM
JohnZ's Avatar
JohnZ
Yes, they will - the hex size on the jackscrew is the same on all of them.
Old Aug 29, 2010 | 08:56 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if you were not all that concerned about it being 100% original any jack from 63-82 will work.
Old Aug 29, 2010 | 09:18 PM
rick66's Avatar
rick66
That's the answer I am looking for. Thanks.
If I stumble across an original later in life I will pick it (assuming it is reasonably priced). But as I found out at Carlisle, they are not cheap.
Old Aug 29, 2010 | 09:44 PM
StingU2's Avatar
StingU2
Default Need a jack
Rick... from what I hear, nothing is cheap at Carlisle.
I would search elsewhere.
Old Aug 29, 2010 | 10:18 PM
rick66's Avatar
rick66
I just did quick search of fleabay...least expensive one was appx $200 (not a mid-year). Mid-year jacks were much higher.
Old Aug 29, 2010 | 11:22 PM
StingU2's Avatar
StingU2
Rick
Here is one you might check into for your '66.
http://www.volvette.com/SP06C.html
Bruce
Old Aug 30, 2010 | 02:50 PM
bosshog8's Avatar
bosshog8
Just for your info a 68 - 82 jack will work to jack up your car but will not fit in your storage area behind the seat. The whole thing is slightly longer and it sits in there all messed up and no way to correct it because the jacking bolt is actually longer. They look exactly the same but one is ~ 9" and the other is ~11" (not certain about the measurements since I too don't have a correct one to measure)
Old Aug 30, 2010 | 03:03 PM
rick66's Avatar
rick66
The one from Volunteer Vette via Bruce in post 7 looks appetizing at this point.
Old Aug 30, 2010 | 03:49 PM
65 vette dude's Avatar
65 vette dude
I went to a "U Pick Um" junk yard and got a jack out of an old wrecked Camaro. It's not exactly correct, but it's close enough, and it was in very got condition......8 bucks.
Old Oct 17, 2010 | 08:27 AM
salty_waders's Avatar
salty_waders
Does it fit in your jack storage compartment?
Old Oct 17, 2010 | 09:25 AM
Nowhere Man
if that is the case find a jack out of a corvair they look very close to the mid year jacks
Old Oct 17, 2010 | 11:50 AM
Astrodokk's Avatar
Astrodokk
I have a jack that came in my '65. I believe it may be a type II though. It's original and in excellent shape, but the crank handle has a bolt and nut holding it together. I can get a pic. I don't particularly care if I keep it or not, since my car is modded, but like I said, it may not be for a '66.
Old Oct 17, 2010 | 03:31 PM
rick66's Avatar
rick66
PM sent
Old Oct 18, 2010 | 11:06 AM
White Monster's Avatar
White Monster
Newbie Vette owner here .... where exactly is the jack storage compartment ?
I don't believe I have a jack, but don't know where to look.
I want one to carry that will work properly.
For now, I just carry a small floor jack without much lift.
Old Oct 18, 2010 | 11:40 AM
Steve439's Avatar
Steve439
It's the recessed compartment behind the seats.
The carpeted cover should have a "jacking instructions" sticker on the under side.
Old Oct 18, 2010 | 12:49 PM
67L36Driver's Avatar
67L36Driver
+2 on the Corvair jack. Been carrying one for years.
You can usually get them cheap.
To Need a jack
Old Oct 18, 2010 | 01:32 PM
White Monster
LOL !!!
Thanks Steve, I didn't even know that was there.
Of course it was empty ... and the "jacking instructions" sticker was almost peeled entirely away.
Guess I'll pick up a Corvair jack as recommended and be done with it.
Anybody know where I can find the "jacking instructions" online somewhere, so I know where the correct jack points are ?
Rick, sorry for the thread hi-jack (ha, ha, ha ... get it ?)
Old Oct 18, 2010 | 02:47 PM
TheSaint's Avatar
TheSaint
How much is a Corvair jack?
Steve439's Avatar
Steve439
You can buy a replacement sticker at the vendors.
The owner's manual also has the instructions.
The recommended jacking points are three inches in front of the rear wheelwell and five inches in front of the door.
