Steering Lube
Steering Lube
What is the recommended lube for the steering gear in a 64? The manual suggests “a lubricant which will provide satisfactory lubrication under all conditions”
I’ve seen steering gears that have a Zerk fitting, (+65?) this one does not.
Thanks in advance
Jim
Thanks in advance
Jim
I use suspension lube. It also helps stop leaks.
