327 mounting points for engine pull
Old Sep 6, 2010 | 12:58 PM
Brumbach's Avatar
Brumbach
Default 327 mounting points for engine pull
I'm nearly ready to pull the standin engine. I've got a "big red" with a leveller. Chains on leveller are too short to do a crossover from exhaust manifold holes at #1 & #8. Is there any reason why I couldn't backout the bolts on the four corners of the intake manifold and hookup there for the pull? Thanks -- Bill
Old Sep 6, 2010 | 01:23 PM
MikeM's Avatar
MikeM
You can. Just use longer bolts.
Old Sep 6, 2010 | 01:34 PM
Brumbach's Avatar
Brumbach
I was hoping you'd be monitoring the forum. I'm using the exhaust bolts to hook up on the four corners. They're longer and will allow for maximum thread use. I'll let you know how it goes. Bill
Old Sep 6, 2010 | 01:59 PM
JohnZ's Avatar
JohnZ
I always use the four extreme corner intake holes for the tilter chains; use 3/8"-16 x 1-3/4" Grade 8 bolts and hardened flat washers.
Old Sep 6, 2010 | 02:05 PM
MikeM's Avatar
MikeM
If you're going to re-use those exhaust manifold bolts, run them down against the lift eyes. If you let them stick up too far, the weight will bend the bolts.
Old Sep 6, 2010 | 02:11 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
The method that always scared me is the plate mounted to the carb flange. I always felt like it put too much stress on an aluminum manifold.
Old Sep 6, 2010 | 02:15 PM
MikeM's Avatar
MikeM
I think the C3 used only one bolt for the decking eye in the rear of the engine on the head. That decking eye carried the rear of the engine and the transmission. I believe it was a single grade 5 bolt. There's not that much weight to shear a grade 5.
Old Sep 6, 2010 | 03:26 PM
Brumbach's Avatar
Brumbach
I did the best I could but I'm working with an uneven surface at the corners of the manifold. Regardless, it'll be a pleasure to buy new bolts after this. Wife is going to help. I told her that "the couple that pulls an engine together stays together". She corrected me and said, "honey, I think that's prays together". So I said "let's pray we get this engine out without damaging my vette!" Don't think she appreciated my humor.
Old Sep 6, 2010 | 03:41 PM
midyearvette's Avatar
midyearvette
the only time i saw one let go was when a bubba bolted the plate with the carb studs, if you use them correctly, it works
i always use an x chain from corner to corner....jmo...
Old Sep 6, 2010 | 03:54 PM
MikeM's Avatar
MikeM
Originally Posted by brumbach
wife is going to help. I told her that "the couple that pulls an engine together stays together". She corrected me and said, "honey, i think that's prays together". So i said "let's pray we get this engine out without damaging my vette!" don't think she appreciated my humor.
:d:d
Old Sep 6, 2010 | 09:08 PM
LouieM's Avatar
LouieM
I thought the same way. However, the engine shop I used (S&S Machine in San Leandro CA) has never had a problem in over 50 years of pulling and building engines using a plate that bolts to the carb flange on the intake, which is aluminum on my L79. Looks scary but works; like anything, though, Bubba can screw it up by being sloppy and inattentive.
Old Sep 7, 2010 | 06:11 PM
Brumbach's Avatar
Brumbach
Engine is out and no damages. Bellhousing and tranny is next. Thanks for the help. Bill
Old Sep 8, 2010 | 06:37 PM
Black60's Avatar
Black60
I've got a "big red" with a leveller. Thanks -- Bill
Bill:
Quit braggin' up your "Big Red". It is immodest of you.
Ralph
(Smallish Red)
Old Sep 9, 2010 | 02:06 AM
MiguelsC2's Avatar
MiguelsC2
Originally Posted by Black60
Bill:
Ralph
(Smallish Red)
Mines called St.Peter
To 327 mounting points for engine pull
