Wanting A Hurst Shifter For My '64
Bud2
Thinking of putting in a Hurst shifter for my trips to the strip. Not willing to rip into the console/floor so the in-line version is out. What's the next best choice?
Bud.
Bud.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
It's the first thing I'd change on the old girls, night and day difference. I used the "comp plus" with a short straight stick on mine, no mods necessary, and the midyear boot will fit over the stick, but the early ones won't.
Received 1,844 Likes
Stock shifters rattle, are clunky, are loose, have a chintzy reverse lock out, and flexible rods.
I bought a dead stock unrestored 65 a couple years ago, totally untouched all the way down to the original shocks. I did not think twice about replacing the shifter immediately, it's now in a box. The next owner can reinstall that POS when he subjects himself to judging.
I did the same in my 64 (38) years ago. No regrets.
I could not disagree more. There is a reason 90% of the originals got replaced with a Hurst Comp Plus (no ripping required).
I have a vintage HURST shifter early 60's era stick and shifter are one no modifications works flawless...after 47 years..stock shifters had a tendency to over shift
Come on guys, give MikeM a break. He still thinks bias ply tires are the best thing in the world. Stock shifters, in a word, SUK. Maybe that's why Hurst made millions on replacement shifters.
Jim
Jim
...and you're blaming the Hurst for breaking your tranny case! hahaha! Is your first name "Arnold" or what? It's a wonder you didn't break your arm!
So, tell me. Since the OP asked about changing the shifter to go drag racing, how much did you drop your ET at the strip when you put your Hurst shifter in one of the remaining 10% of the cars left with the stock shifter?
I'd like to know how much ANYBODY dropped their ET for that matter. If in fact they did drop an ET, was it really worth the time/effort/money or is it just something to talk about?
The question was about drag racing, wasn't it?
I've had my share of Hurst shifters and I've had my share of OEM shifters including the really junky ones they put on pass cars and the fake ones they put in GTO's.
One of my Corvettes had a perfectly good Hurst shifter in it when I got it. Didn't take me long to change it back with one of the 90% cast off shifters I had.
Like you, I bought a totally dead stock, untouched, undrestored, original shock car about 38 years ago. It still has the stock shifter in it and it doesn't have all those bad things you said about OEM shifters 'cause IT"S NOT WORN OUT!
I am a believer in HURST shifters. Have been since the mid 60's.
When I had my 75 Camaro (which I purchased NEW, seven miles on the odometer when I drove it home from Reedman Chevrolet in Langhorne, PA) with the stock linkage on a 3 speed transmission it locked into second gear at about 43,000 miles. The transmission was fine. The wonderful factory shifter was cagged out completely.
I replaced it with a HURST 3 speed shifter. The shift pattern was tighter, the shifter never gave me a bit of trouble for the additional 90,000 miles I put on the car before I traded it in.
As to Mike's question about dropped ET's on the drag strip due to changing shifter I don't have an answer. What I DO have is the knowledge that when I did my drag racing ( and I did my fair share) I DID have factory shifters lock into gear (most commonly second gear) and cause a DNF. This was not in Corvettes. This was in GTO's and MOPAR's. I NEVER had a HURST shifter do that to me.
I am not and do not claim to be the authority on this matter, I just know what I know from hands on experience.
Rich
Got my 66 years ago, and had a hard time driving it home because of the sloppy shifter. It was also on long throw which was like driving an old Volkswagon. First thing I did was to rip it out, rebuild it, and change to short throw. While it was more precise in it's movement, it now had the buzzes/rattles, and the rods flex under fast shifting resulting in the tranny locking up, as many of you know. More than once I had to squirm under and reach the rods to release the jam. The noise was so irritating I used to wrap a towel around it to muffle the noise. Anybody who likes the original units must drive like a hard of hearing old lady on her way to church. Hurst with a look-a-like stick is da bomb.
Rich
It took me less than a month to destroy the new OEM shifter in my new pass car. I took it out, re-inforced it and put it back in. It's still in there to this day. But, the pass car shifters are just a cheap imitation of the Corvette shifter.
One thing a Hust shifter has over the stock units is that when shifting hard and fast the Hurst has stops that are set so that you don't try to override the gear mesh saving wear and tear on the transmission
Bottom line. Factory Chevy shifters suck! Period! For less mis-shifts,jammed shifters etc.. Buy a Comp plus shifter. Heres a link to a new one.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050B
