How does speedo gear seat/seal in speedo housing?
O.k., I've been reading numerous threads on various speedo gear issues but I can't find my answers so I'm looking for help on my '64 roadster.
I have a new cluster and have done a reverse drill test of my cable back to my cluster - nice steady speedometer reading. However, when I hook cable to speedo housing in the tranny - I get nothing. I noticed transmission fluid around the speedo housing so I pulled out speedo housing/gear and noticed the o-ring is pretty shot. However, the 21 tooth red driven gear looks to be in perfect order! I've not dropped my tranny so I can't see the drive gear.
In looking at the configuration of housing/driven gear, I can't tell if something is missing that should retain the driven gear in the housing? Something that would also keep the transmission fluid from flowing along the driven gear shaft and into the speedo cable. When I pulled my housing, the driven gear fell easily out the back. If some sort of bushing is suppose to be there, mine is missing. Might this also help in keeping the driven gear pressed against the drive gear?
Before I took all apart 2 years ago, my speedometer was bouncing but I believe that was due to dry cable. I now have new cluster, speedometer, and cable but the housing, speedo gear, and transmission are original. When all hooked up, I get nothing.
Any leads would be appreciated! If I'm missing a bushing, would love a photo if someone has one handy! If I'm not missing a bushing, what keeps the transmission fluid from leaking past the driven gear shaft?
If you have good O rings on the cable adapter, and it fits snuggly in the tailshaft bore, there shouldn't be a problem with it.
Received 1,857 Likes
The later speedo gear adapters had a rubber internal seal to keep trans lube out of the cable (see photo below), and they're interchangeable with the early style that didn't have the seal; all the vendors have the later style.
Still no speedo
JohnZ, thanks for the pic.
Went to a very reputable tranny store and was able to pick up a complete housing WITH bushing. Put in my 21 tooth red gear (in perfect order) and re-installed in the tranny. Went in smooth and easy. Went for a test drive hoping to have speedo register and NOTHING
I guess there must be something wrong inside the tranny (or my 21 tooth isn't compatible)? I have no idea what it takes to drop the tranny to get to the internal drive gear?
Ideas?
Ideas?
Location: going faster miles an hour...with the radio on in browns mills new jersey
Have you tried using a real small screwdriver in the end of the driven gear to see if you can turn it? It shouldn't turn.
You can inspect the drive gear with a mirror and flashlight.
To access the drive gear you need to pull the transmission and remove the tailshaft.
If you go this far, you might as well replace the tailshaft bushing while you are at it.
I'll try the small screwdriver insertion later tonight. I'll also see if I can find a dental mirror to see within. Thanks for the leads and I'll post a follow-up as soon as I get under there again.
Do I have mis-matched gear?
Going by the archives, sounds like I might have the wrong driven gear (too small a diameter?)? How do I go about determining what tranny I have, what drive gear would be in it, and what driven gear I should have? Though I'm learning a ton and willing to tackle anything (even if I have to drop the tranny), this is a new area for me.
Well, it failed the screw driver test - driven gear turns freely when the housing is seated. Using a mirror, the metal drive gear is there and appears to be in perfect shape.
