Fuel Problem (?) with Split Fuelie
Old Sep 17, 2010 | 04:29 AM
JR Germany's Avatar
JR Germany
Default Fuel Problem (?) with Split Fuelie
Hi,
have a problem with my Split Fuelie and my mechanic has no more ideas.
Engaging the clutch at speeds over 30 mph stalls the engine. At lower speed everything is ok.
If connection between air intake filter and throttle body is removed the problem also doesn't occur.
Main diaphragm vent tube from throttle body to fuel meter is connected and sealed.
In any other condition engine runs perfectly without any problem.
Does anybody have an idea?
Thx and regards from Germany
JR
Old Sep 17, 2010 | 01:52 PM
JohnZ's Avatar
JohnZ
Could you define that condition a little more clearly? Do you mean pushing the clutch pedal down (DISengaging the clutch over 30 mph)?
Old Sep 17, 2010 | 05:39 PM
JR Germany's Avatar
JR Germany
Sorry! Yes, of course.
(Would have been easier to describe it in German).
Regards
JR
Old Sep 17, 2010 | 10:35 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Split fuelie?????????????????????????????????? ??????
Tom Parsons
Old Sep 17, 2010 | 11:14 PM
62Jeff's Avatar
62Jeff
Tom Parsons
A 1963 split window coupe with fuel injection. Give him a break Tom, his English is far better than most of our German
Old Sep 19, 2010 | 03:00 PM
JR Germany's Avatar
JR Germany
Thx, Jeff!
Ok, car has been specified, problem has been specified.
Any suggestions?
JR
Old Sep 19, 2010 | 03:36 PM
MikeM's Avatar
MikeM
Thx, Jeff!
JR
Not really. See post #2.
Old Sep 19, 2010 | 04:18 PM
JR Germany's Avatar
JR Germany
Hi Mike,
see post #3!
Again:
The problem occurs when pressing clutch pedal down, so revs going down and engine is off.
At speed <30 mph everything is ok.
After removing connection between air intake filter and throttle body also everything is ok.
Regards
JR
Old Sep 19, 2010 | 06:54 PM
MikeM's Avatar
MikeM
Hi Mike,
see post #3!
Again:
Regards
JR
I somehow missed post #3.
Does the engine idle okay?
When you have the engine revved at highway speeds and let the engine fall back to idle, it stalls? What happens if you control the engine speed drop with the throttle until then engine speed gets back to idle speed? Will it stay running?
Old Sep 19, 2010 | 07:33 PM
JR Germany's Avatar
JR Germany
Hi Mike,
idle is ok if car is slower than 30mph or air intake is not connected with throttle body.
At higher speed engine stalling can be avoided with throttle but there is no stable idle. Leaving right pedal leads to engine stall.
Regards
JR
Old Sep 19, 2010 | 08:14 PM
MikeM's Avatar
MikeM
Hi Mike,
Regards
JR
Usually taking the air cleaner loose from the air meter results in erratic running due to turbulence past the P ring.
Any chance the air cleaner is not passing enough air?
How about the idle mixture screw adjustment?
Have the lean/rich stops been set with gauges or just seat of the pants?
Do you or your mechanic have any kind of service manual?
Old Sep 20, 2010 | 12:32 AM
Dads61's Avatar
Dads61
I've seen this with modern cars with cold air intakes on them with no diffusers...the engine is flooding itself with air(hence going too lean) and stalling. The clue is the fact it is related to vehicle speed only, not engine speed. The fact that the air cleaner coming off 'fixes' it suggests something is not right there..a pic for us to see perhaps would help..
To Fuel Problem (?) with Split Fuelie
