The directional signals on my 66 coupe have me scratching my head. When I use my turn signals it causes all the directional signals to flash. The dash indicators also flash. I had changed the signal cam in the steering wheel a few years back. I pulled the steering wheel off thinking the wires were shorting. Everything was good. No chafed or damaged wires. If I pull out the 4 way flashers they work. I also replaced the two flashers. Same problem. Has anyone had this problem or have an idea as to its cause? I remember having a similar problem 25- 30 years ago on this vette. I just can't remember how I fixed it. Any help would be greatly appreciated.
Dave66
These pictures I took a few years back might help. The contact block tangs get bent out of shape and when you move the turn signal lever, the cam on it moves more than one of those tangs and you get more than two things working. Or, the tangs are already bent and making contact without moving the turn signal lever. How that happens, I don't know. So, be patient and bend them back into shape....or replace the whole turn signal switch.
In 66, four way flashers were an option. The flasher mounts on the parking brake bracket. The flasher plugged into the directional harness mounted on the steering column. I bought one for about $175 at a show. I see them from time to time for sale in the Driveline. Jerry
Sounds like a ground issue at the housings. If you loose your ground at the housing the circuit completes itself by passing through the body of the 1157 bulb then across the light side filament which energizes the light circuit giving you four way flashing lights. Take off the lenses so you can see the bulbs and if both filaments are lighting on one side then that is the side you have lost your ground on. to find if it is in the front or back pull the bulbs one at a time and when you pull the un grounded one the other side will stop flashing.
Thanks for all the helpful suggestions. Worked on the car today before reading your replies.
Found a loose ground wire and a bad bulb on the r/rear taillight today. Fixed both, problem the same. I paid more attention to the lights when they were flashing.
With the key on and the r/turn signal engaged, only the r/signal indicator on the dash flashed along with both rear turn signals and the right front turn signal.
When I used the left turn signal. Only the left dash indicator flashed along with both front and rear turn signals. The lights just don't go on they flash. Juice jumping across somehow. Will change the bulbs and check the grounds next time I work on it If thats not it, move on to the switches.
Thanks again
Just a few things that might help. I don't know how you are testing for grounds but keep in mind that a test light used at the housing can show a ground if it is coming through the light circuit through the other bulbs. Sorry that's not a great discription but think about it and you should get it. I don't know the switches in these cars well so the other guys may be right but seems to me the indicators would both be going if the switch was the cause, again I don't know these switches well.
The indicator and the front lamp are always powered by a line from the flasher on a separate circuit inside the turn switch because the brake light switch powers both rear lamps through the turn switch - so that the switch can interrupt power to one of the brake powered rear lamps and turn it over to the flasher powered circuit.
In his second post dave66bb indicated the left and right activity is different and the left lamp activity was an ambiguous description (use of the word both). If both front and rear LH lamps flash with the indicator it's working properly. If both front and both rear flash with the LH indicator both sides have problems.
