Torque ?
Old Sep 23, 2010 | 04:34 PM
shemp's Avatar
shemp
Default Torque ?
Are there torque specs for the steering tie rod ends and the steering box frame mount bolts? I looked in the assemmbly manual and those were two I could not find. If they are in there what page # ?
Shemp
Old Sep 23, 2010 | 05:29 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Tie rod end nut...35 lb. ft. Steering box to frame 30 lb. ft. Dennis
Old Sep 23, 2010 | 07:57 PM
shemp's Avatar
shemp
OK Dennis enlighten me,where did you find those numbers ? Shemp
Old Sep 24, 2010 | 02:38 AM
Nev Williams's Avatar
Nev Williams
Shemp
Try this table it's a fairly good guide when you have no other data
Grade 2 rubbish bolts, Grade 5 Med Tensile & Grade8 HTen.
The lower number suffix on each bolt size is UNC, Higher number UNF
Old Sep 24, 2010 | 10:59 AM
magicv8's Avatar
magicv8
Shemp
I put a torque chart that you can save and print linked from the help section that is near the bottom of my web page at http://home.mchsi.com/~magicv8
Old Sep 24, 2010 | 01:13 PM
shemp's Avatar
shemp
Thanks Magic, I'll print that out Shemp
Old Sep 24, 2010 | 01:14 PM
Bluestripe67
Shemp, all the specs are in the '67 Chassis Service Manual. Dennis
Old Sep 24, 2010 | 02:26 PM
shemp's Avatar
shemp
Which I don't have. I just have the assembly manual. Shemp
Old Sep 24, 2010 | 02:36 PM
Ron Miller's Avatar
Ron Miller
Which I THINK (without checking) that it's also in. As well as there, I've got torques scattered about in various repair manuals that I own. Still, it's really nice to be able to print out a copy such as MagicV8's and take to the shop, get your greasy hands all over it, an print another when you need.
Old Sep 25, 2010 | 08:10 PM
magicv8's Avatar
magicv8
All the figures in the chart on my site are from the Chassis Service, Chassis Repair, and Assembly manuals.
I got tired of searching manuals with greasy fingers too.
To Torque ?
