Copper ignition part
Old Oct 3, 2010 | 01:15 PM
jbutler's Avatar
jbutler
Default Copper ignition part
What's the copper part for?
Is it a light housing?
Name:  ignation switch.jpg
Old Oct 3, 2010 | 02:47 PM
62Jeff's Avatar
62Jeff
Attachment 47658783
Yes. The large ring goes around the threaded shaft of the ignition switch housing just before you install the switch housing into the cluster. The light bulb socket plugs into the smaller hole.
Old Oct 3, 2010 | 03:14 PM
midyearvette's Avatar
midyearvette
that looks like it may be a universal part for a c2?...if so, you may have to modify your connector to make it fit....jmo....
Old Oct 3, 2010 | 04:26 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
It is a universal switch, but it actually fits the harness connector. No issues there.
The real issue is mechanical. The thin, stamped lock nut that snugs against the back of the instrument cluster is worthless.
In lieu of the stamped lock nut, I installed an additional regular bezel nut (turned backwards) on the back side of the cluster. It has enough threads and strength to hold the switch stationary.
I did have to shorten the extra nut slightly to have sufficient threads protruding through the cluster.
Jim
Old Oct 3, 2010 | 04:42 PM
jbutler's Avatar
jbutler
Thanks everyone,
now, what does it light up?
Old Oct 3, 2010 | 06:20 PM
jim lockwood
Thanks everyone,
The key opening. Turn on the instrument cluster lights at night and you can see the slot for the key.
Old Oct 3, 2010 | 07:12 PM
jbutler's Avatar
jbutler
Thanks!
There was a new ignition switch and the lamp housing in the spare parts that came with the car. But there wasn't a housing on the installed switch.
I haven't tested the old switch to see if it needs replacement.
To Copper ignition part
