Door gaps
Old Oct 6, 2010 | 11:23 AM
40ZR1's Avatar
40ZR1
Default Door gaps
New front clip and rear quarters, how much door gap should I have. I have about 1/8" at front and rear of door, is this too small a gap. I'm worried that body flex will make the door and rear quarter panel (especially at top of door) hit each other. Don't want to chip the paint!
Old Oct 6, 2010 | 11:42 AM
MikeM's Avatar
MikeM
I believe 1/8" is spec with a +/-.
If it were mine, I'd open the margins to 4mil. and make them straight and even.
Old Oct 6, 2010 | 12:27 PM
65 vette dude's Avatar
65 vette dude
For what it's worth, I checked my gaps on my 65 ragtop, and they are about 1/4" on both doors, front and back. I think your concerns about body flex with those gaps are well founded. I would be afraid to jack up the car.........sure looks nice though.
Old Oct 6, 2010 | 12:31 PM
fullcontrol's Avatar
fullcontrol
Paid Senior Member
If you can stick a paint stir stick in the gap with almost zero drag then you are right on.
Old Oct 6, 2010 | 12:36 PM
John McGraw's Avatar
John McGraw
If you properly install the door alignment wedges, the gaps should be fine. The wedges are designed to prevent the gaps from closing up during frame flexing. I like running tight gaps as well, and I have no problems, but my wedges are set tight. I use a paint stick as a gauge as well.
Regards, John McGraw
Old Oct 6, 2010 | 12:43 PM
JohnZ's Avatar
JohnZ
Door-to-fender and quarter panel gap spec is 1/8" to 1/4"; all body fit gap and flush specs are shown in UPC 11/13 in the Assembly Manual.
Old Oct 6, 2010 | 12:45 PM
MikeM's Avatar
MikeM
As illustrated in the '63 shop manual,
door/fender is 1/8"-1/4"
hood/fender is 1/16"-1/4"
hood/headlight panel is 1/8"-1/4"
headlight bucket/opening 1/16"-3/16"
There may be more or later information elsewhere. When you run very tight margins, you better be good with the flushness or out of flush will stick out like a sore thumb.
Old Oct 6, 2010 | 01:23 PM
fullcontrol
Paid Senior Member
Good point Mike, the closer together the easier it is for the eye to see the difference in the levels between the adjoining surfaces.
Old Oct 6, 2010 | 04:40 PM
40ZR1's Avatar
40ZR1
Hey guys, thanks for the quick feedback! Didn't remember about the the door wedges and I like the small gap, so I'll use the paint stick as a gauge. And the body panels will be matched to each other for good smooth flow.
Bought an el-cheapo HVLP gun from HF and using Evercoat (?) primer will start blocking the rear of car, working my way forward.
With the major 'glass work completed, I brought my car home to an A/C garage, now I work a little and watch TV, too!
Leaving tomorrow for Cruisin' the Coast, lots of great cars, cops are pretty cool as long as you're not too stupid
CJ
And, check out my bucket seat! Did that so I could wash 'glass dust off and still drive in and out of garage and around yard. Also, did a few burn outs on driveway.
Old Oct 6, 2010 | 05:20 PM
robert miller's Avatar
robert miller
Default ttt
Looks like that B/seat is hooked up good... Looks like it will be a nice car when done.... Good job...
Old Oct 6, 2010 | 06:05 PM
ktchir's Avatar
ktchir
Love the seat....does it come in RED ?
Old Oct 6, 2010 | 07:18 PM
65ZR1's Avatar
65ZR1
What are door alignment wedges and how are they used??
Thanks,
Old Oct 6, 2010 | 10:26 PM
40ZR1's Avatar
40ZR1
65ZR1, if you look at the picture with the bucket seat at the top of the door pillar you can see four holes, the two vertical inside are aluminum rivets that attach the door pillar to the birdcage. The two outside vertical threaded holes are for the door wedges and match two threaded holes in the door. They are plastic (?) with elongated slots for adjustment.
Old Oct 6, 2010 | 10:32 PM
fullcontrol
Paid Senior Member
Same wedges are used on the deck gaps on the convertible.
Old Oct 6, 2010 | 11:04 PM
Stewart Allison's Avatar
Stewart Allison
They look good those gaps Lexus/Audi/Merc gaps all round ! Stewy
Old Oct 7, 2010 | 05:53 AM
65ZR1's Avatar
65ZR1
Thanks for the info!
Old Oct 7, 2010 | 05:25 PM
shemp's Avatar
shemp
Is that a Vespa on the bench? Gaps look OK to me. Shemp
To Door gaps
Old Oct 7, 2010 | 08:23 PM
40ZR1's Avatar
40ZR1
Yeap, 1954 Allstate Vespa. Bought it several years ago from original owner (fulfilling my childhood dream), last registered in 1957. Took it completely apart rebuilt the mechanicals, replaced deteriorated rubber and cleaned it up. 'They're only original once.'
Hey Shemp, what did you finally use to clean that trans case? "Inquiring minds want to know"
CJ
Old Oct 7, 2010 | 08:30 PM
Stewart Allison
[IMG]http://i266.photobucket.com/albums/ii270/40ZR1/100_1632.jpg[/IM
G]
CJ
What's an old Vespa worth over there ! Damn expensive here.. Stewy
Old Oct 7, 2010 | 09:49 PM
40ZR1's Avatar
40ZR1
Stewy, don't know what they're worth but the parts are damn expensive. Had to have a couple of ball bearings made. New ones are too wide, thankfully I found a small bearing company in California that surface ground the widths of the inner and outer races before assembly.
As an aside, how do you copy a post as you have done? If I can't beat it with a 20 pounder, it's rocket science to me! Took me two tries to post this.
CJ
