battery cable length
Old Oct 7, 2010 | 09:58 AM
JPB04619's Avatar
JPB04619
Default battery cable length
i know the information is there somewhere but i searched and can't find it.....what i would like to know is the length of the positive and negative battery cables on a 64 vert 327 365hp , non a/c....appreciate any help john b
Old Oct 9, 2010 | 10:06 AM
JPB04619's Avatar
JPB04619
any one..................
Old Oct 9, 2010 | 10:18 AM
62Jeff's Avatar
62Jeff
A quick search of Corvette Central's on-line parts listing shows part number 172105
Black, positive = 18 inches
Brown, negative = 24 inches
Old Oct 9, 2010 | 03:27 PM
Donald #31176's Avatar
Donald #31176
If you re making custom battery cable consider using larger sized wire say 1/0 or 2/0 with HD ends & terminal.
Old Oct 9, 2010 | 06:04 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Is that a trick question...? Ummmm...........OK, I'll bite..........Is the correct answer......As long as you need them to be...!?
Old Oct 9, 2010 | 09:12 PM
JPB04619's Avatar
JPB04619
thanks i thought this was a corvette foreum,now everyones' a comedian.....lol............ that's what i what to do ,custom cables 2/0 , but i would like to know the stock lengths
sh
Old Oct 9, 2010 | 09:21 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
sh
2/0 is waaay more than you need for a stock length cable on a small block. If you are into overkill go for it. I don't think you're gonna gain much.
IMHO you would be better served with stock 4 gauge cables and running an additional ground from a bell housing bolt to a battery box to frame mounting bolt.
Rich
Old Oct 9, 2010 | 09:59 PM
Powershift's Avatar
Powershift
Rich
Agree that 2/0 is way oversized for stock length cables. I used 2/0 cables when I relocated the battery to the trunk area in my 1969 AMX due to the very long positive cable length. Even then 2/0 was oversized....but I wasn't about to take any chances. For installation in a typical car, I think 2/0 gage will handle up to 400 amps intermittant starter current with essentially zero voltage loss.
If you use the thick cable, get welding cable with the ultra-fine copper strands, as it is more flexible. I also brazed/soldered the end connections on the cables...but doing this causes the final 2 inches or so of the connection area to become stiff. You need to determine what is best in your case.
Larry
Old Oct 9, 2010 | 11:10 PM
Kerrmudgeon
Sorry, couldn't help myself, you didn't say 'correct' or 'stock'. I ran 1 gauge cable when I installed my battery in the storage compartment on my 66, but that's a long run, I never had much voltage loss with those big guys....K
Old Oct 10, 2010 | 09:22 AM
Donald #31176
Rich
1/0 or 2/0 wire is probably overkill but there is no downside to using it except for about $10 extra for materials. In my case before changing over to thicker cable the turn signal would not flash @ idle unless I rev ed the engine. It will now.
Old Oct 10, 2010 | 12:16 PM
JPB04619's Avatar
JPB04619
wow , thanks guys for the imput................john b
To battery cable length
