Knock sensor
Old Oct 10, 2010 | 02:09 PM
Glasshole's Avatar
Glasshole
Default Knock sensor
I am installing a modern EFI unit on my 63'. While not mandatory, I want to add a knock sensor. The challenge is with my solid lifter valve train possibly setting off the sensor with false readings. I have to change out my stock 461x FI heads for some vortec heads anyways and was thinking maybe some roller tip rocker arms would quiet things down a bit. I've also heard that you can wrap some Teflon tape around the threads of the sensor to desensitize it a bit. Thoughts & suggestions please.
Old Oct 10, 2010 | 02:34 PM
JohnZ's Avatar
JohnZ
The later production knock sensor location monitors the frequency/amplitude of detonation noise emanating from the cylinder walls; it won't "hear" the valvetrain.
Old Oct 10, 2010 | 02:59 PM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Here are a few links that may be helpful:
http://www.chevytalk.org/fusionbb/sh...rch/1/#1970546
http://diagnosticnews.com/tech/engin...ensors-part-1/
http://diagnosticnews.com/tech/engin...ensors-part-2/
Old Oct 10, 2010 | 03:07 PM
mikem350's Avatar
mikem350
Maybe thats also why the ks mount down low in the water jackets?
To Knock sensor
