From: Media, Delaware County, Penna (Next door to Philly)
A/C Boxes the same?
Are the heater-a/c boxes in the 66 Convs all the same or is the A/C box completely different. If so, how can I tell if I have the A/C Box.
I have a car that was an air car but somewhere along the way it was removed....The firewall has the parts needed still attached Is there anything UNDER the dash I should look for to make sure nothing was "changed out"?
The dash vent and cable holes were filled.
This is the A/C-Heater box from my 65. Should be pretty much identical to a 66. The item circled is a vacuum control valve that is only present on an A/C car.
Thanks for the info on that guys....You boys are FAST! I just posted that question within the last 1/2 hour or so......
Ill check mine tomorrow but Im pretty sure I have seen that on my heater box as well.....which is good news for my futer re-installation of A/C.
