Source for Temperature Sending Unit
Old Oct 12, 2010 | 12:07 AM
C2Dan's Avatar
C2Dan
Default Source for Temperature Sending Unit
I want to install a new temperature sending unit; the current one works fine at 180 degrees but progressively overstates the actual temperature (as measured with an IR gun) as the coolant temperature rises above 180. I understand that some don't work well while others do. The units sold by Zip, DeWitt and Corvette Clocks by Roger claim to be in the latter category. Any recommendations? Thank you!
Old Oct 12, 2010 | 06:44 AM
rick66's Avatar
rick66
TU 5 from Auto Zone has been the most accurate (matches my IR gun reading) and I have tried several.
Old Oct 12, 2010 | 08:11 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Before you do that, get a cheap aftermarket or used gauge that works correctly and hook it up to your current sender. The old gauges do some weird things quite often. K
Old Oct 12, 2010 | 09:16 AM
Donald #31176's Avatar
Donald #31176
You can contact Mary Jo (vettegal.com) to see if she still has old Delco senders from the 60s. I think she was selling them for $40. Another source could be the junkyards if you have them in your area. Look for any 70s GM vehicle that was gauge equipped. ( Cold- Hot indicator not idiot light)
Old Oct 12, 2010 | 12:26 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
On my boat engine (420SB), I have installed mechanical temp gauges directly into the water passage of the intake manifold. If an unused threaded hole is available in a manifold, this may be a viable option for monitoring temps.
Tom Parsons
Old Oct 13, 2010 | 09:14 PM
C2Dan's Avatar
C2Dan
Thank you. But it turns out that she seems to specialize in C1 parts; mine is a C2.
Old Oct 13, 2010 | 09:44 PM
Donald #31176
I believe C-1 & C-2 Temp senders are calibrated the same.
Old Oct 13, 2010 | 11:06 PM
Glasshole's Avatar
Glasshole
The one I got from Zip works great. It is accurate within 5 degrees to the IR gun. Seems close enough for me.
Old Oct 14, 2010 | 01:05 PM
C2Dan's Avatar
C2Dan
Sorry; I think you're right--most vendors sell the same unit for C1s and C2s. But it turns out that she has no senders for sale right now.
Old Dec 9, 2010 | 09:20 PM
C2Dan's Avatar
C2Dan
I had the DeWitt sending unit installed. It seems to work fine, except that the gauge now doesn't even reach 180 degrees and clearly understates the actual temperature. Oh well, at least my wife will no longer bug me because the gauge goes way over to the right.
Old Dec 9, 2010 | 09:25 PM
1snake's Avatar
1snake
Mine from them does the same. I tried a couple of the TU-5 units and got wildly different readings from both of them. I ended up using the one from DeWitts only because I couldn't handle the gauge reading too hot even though I know it's not overheating.
Old Dec 9, 2010 | 09:48 PM
Moto One's Avatar
Moto One
I went with the TU5, and it match's IR gun, and meat thermo. So I'm happy.
Mark
Old Dec 9, 2010 | 09:52 PM
Stewart Allison's Avatar
Stewart Allison
I got sick of the after market senders reading to high as well. So I got hold of an original delco and it's readings to my gauge are perfect ! Stewy
To Source for Temperature Sending Unit
