58 Frame Question.
Front of frame to floor: Pass Side = 8-5/16"/Driver Side 8-1/8"
Rear of frame to floor: Pass Side = 7-9/16"/Driver Side 8-3/8"
Rear Kick-up to floor: Pass Side = 12-11/16"/Driver Side 13"
My question is "Is this okay or should I remove the X-member and start over"? If someone wants to see the picture just give me your e-mail address and I'll e-mail it to you. I'm totally confused to whether this is okay or not. A friend said it would be okay but I'd have to shim it a lot.
Did the removal of the front crossmember cause this? If so then will putting a new one on straighten it out? Just trying to figure this out before I have it soda blasted and painted.
Thanks ahead of time for any and all help!!!
58n65
Metal tends to warp around when you weld it. Did you have the frame securely fastened in place when you welded it?
Did you tack weld the cross member at several places before the final welding?
To more accurately measure how much the frame is warped, use something like 4" x 4" or 6" x 6" wood blocks to support the frame at two points on the driver's side near the body mounts. Support the passenger side at one point about half way between the two body mount points. Use a carpenters 4' level and shim the driver side so that it is perfectly level. Then lay the level across the frame at the center point and level the frame from side to side by shimming just the passenger side. Now lay the level on the passenger side and see how level it is. Also check the frame from side to side at the front and rear.
Charles
"How level is your floor?" It's pretty level.
"Metal tends to warp around when you weld it. Did you have the frame securely fastened in place when you welded it?" Actually I didn't. Didn't even think about the metal warping while I welded it or I would have.
"Did you tack weld the cross member at several places before the final welding?" I tack welded it to hold it in place then I welded each section until it was complete. Maybe I should have welded a small section and then went to a different side (after the tack weld)....again it didn't cross my mind.
I have some 6" x 6" blocks so I'll test your recommendation this weekend....hopefully.
Thanks again for the help. I'm thinking more and more that I should start over....YIKES!!! Maybe I'll bolt the front crossmember back to see if that helps also.
58n65
Front of frame to floor: Pass Side = 14-11/16"/Driver Side 14-1/2"
Rear of frame to floor: Pass Side = 8-1/8"/Driver Side 9-3/8"
Rear Kick-up to floor: Pass Side = 17"/Driver Side 17-3/8"
Center of frame: Pass Side = 6-1/8"/Driver Side 6-1/8"
I only had to shim the front driver's side just a hair to get it level all the way around.
Thanks again for the help!!!
Dex.
