67 steering column support bracket ?
I am building a 67 coupe pretty much from boxes. Just purchased the flaming river tilt but I dont have the support bracket that will weld to the column. Does anyone know where to locate one aftermarket or ???
Have looked all over the net but not having much luck.
Is the 68 the same ? maybe other c3 models thru early 70s?
Any options would be appreciated.
Stew.
________________________________________ ________________________________________ _________________
I guess 68 is the last year with this style bracket but maybe posible to use the 65 66 brackets which are available but will they fit the 67 bird cage?
volvette.com
Thank you for the reply.
Any more clues ?
Looks like that is the problem (after spending serious time looking on the net), so I have been trying to find old columns to scavage these parts from.
If anyone has one maybe from a junked column I would be happy to purchase.
It would be a shame to tear up a rebuildable column, so wosrt case I could fab the part.
Thanks again
Stew.
