Trashed out early Vette ?
What made you wait 18 years to go for it ??
The VIN will be on a plate held to the driver's side door jam with phillips screws (open the driver's door, look under the door hinges), until early 1960 corvette production.
In early 1960 production it moved to the top of the steering column just forward of the firewall (open the hood and look at the top of the column for a spot-welded plate) where it stayed through 1962 production.
1963-67 corvettes have the VIN as well as a Trim plate mounted under the glove box in the passenger compartment.
Welcome to the forum, and good luck!
Jeff
Corvette bodys even rough are worth something. I sold a body cut from the firewall back for 2500.00 without doors, trunklid, body or decklid. My advice is to drag it out, put the body onto a trailer. Then take it to the local car wash for presure washing. Take some pictures and sell it. You will get some good money for it. If you have a vin then get it titled. Having the title will add quite a bit of value. Also, you might want to see if you have any extra parts for it. These could even add more money.
,,,,,,,, No I did not get the hood open but tried,,,, hood call out "427" the owner is trusting imop her word is good enough,,,,,,,,,,,,, besides that how many women even know what a 427 Tri Power is , this was the husbands car and he passed away years ago thats where the sentiment comes from.I will be back to see the car anyone want explain where the hood latch is. I looked but could not find it..
a 4 speed
and a Tri Power
Can I get those options on a 57 answer NO and thats why this 67 is better
