My 327 Engine
Old Oct 24, 2010 | 01:56 AM
60 Gasser's Avatar
60 Gasser
Default My 327 Engine
Having trouble posting pictures but I'll work on it.
The 1965 Engine I asked about a week ago -- Thinking of trading it for a pair of ET III wheels. Trying to find out how original it is and I've come to the conclusion it's untouched & low mileage. No ridge at the top of the cylinders & they seem to have not been cut.
However the purchaser asked about the markings on the top of the pistons , there are none. He asked about .030 etc.. and a TRW or other part number.
I used a dial caliper & got exactly 4.00 and the pistons are cast on the underside of the top with the number (as best I can tell) 3795337 GM. This is the engine with the windage tray & filter canister & cast date of July 1965. It does have a hydraulic cam (I previously thought no cam was in the block)
The casting # ends in 714. Do these seem to be the original pistons? I've had the block since approx 1978-80.
Was there a 350 HP engine in 1965? I'll e-mail pictures so someone can post My E-mail is RPAdomitis@NWtec.com
Old Oct 24, 2010 | 02:06 AM
62Jeff's Avatar
62Jeff
Yes there was a 350 horse engine in 1965. I've sent you an e-mail regarding your photos.
This is one of the pistons out of my 65 350 horse car
Old Oct 24, 2010 | 04:26 AM
62Jeff's Avatar
62Jeff
Here are Richard's engine photos...
Old Oct 24, 2010 | 10:10 AM
MikeM's Avatar
MikeM
Looks like that block has frozen and cracked. Hard to tell from the photos though.
Pull a bearing insert and look for the date stamped on the back side of the shell.
Looks like a factory built SHP with the blue paint on the main caps and outside the block, yellow paint swipe on the crank. Whether it's original or not is of no consequence as everything there will have to be redone/replaced.
Old Oct 24, 2010 | 10:37 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Yes the block does look cracked.
Doug
Old Oct 24, 2010 | 01:35 PM
60 Gasser's Avatar
60 Gasser
Default Doug & Mike M: regarding block looks cracked
Since I'm a new member here, is the cracked block kind of an initiation process/inside joke?
Otherwise
Where do you think it looks cracked? I'll wire brush it & check closely. I don't want to trade this engine & later find out it's bad.
Also whats the best way to check for cracks without taking it to a shop? SHP= special HP option?
Old Oct 24, 2010 | 02:40 PM
MikeM's Avatar
MikeM
No, I'm not joking. Look at the crooked line, parrallel to the block deck. halfway between the lifters and block deck. Both sides.
It hard to tell from the picture but that's what it looks like. Sometimes, when the block freezes and busts the block, that's right where you see a crack. Look on the outside of the block, same height.
Then again, maybe you're okay.
Old Oct 24, 2010 | 10:55 PM
60 Gasser's Avatar
60 Gasser
Default No Cracks in the block
only oily lines-- even the outside is solid.
#2 the rod caps are ground with a slight concave radius. & each is numbered rod & cap by hand with one of those electronic etching tools. Looks like someone put some time into this engine. Does the concave cap possibly indicate a balance job?
Thanks again
Old Oct 25, 2010 | 12:16 AM
BLOCKMAN's Avatar
BLOCKMAN
Looks like some one rebalanced the crank before plus if you look its has a BBC oil pump!!
Old Oct 25, 2010 | 11:59 AM
LonR's Avatar
LonR
I also have concerns about the possible cracked block that may be just be oil lines. Didgital camera's can make things look good and bad! Can someone smarter than I circle the lines in question and repost pic so 60 gasser can check and make sure we are looking at the same thing? Thanks
Old Oct 25, 2010 | 12:06 PM
Blk63Vette's Avatar
Blk63Vette
Yes
It does look like a crack to me too..I give back the block..Get your mag wheels back
Old Oct 25, 2010 | 12:10 PM
LonR's Avatar
LonR
Originally Posted by Blk63Vette
Yes
Not giving up on the motor till it's proven either way!
Old Oct 25, 2010 | 12:59 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
If this is what is being discussed...I agree....looks suspicious and not like a typical oil stain...
Old Oct 25, 2010 | 01:14 PM
MikeM's Avatar
MikeM
The other side is the same way plus what looks like a veritcal crack on each side between the center cylinders.
If that engine was run with a crack in it like what it looks like, steam could have cleaned the oil off above the crack, explaining the difference in the color of the surface????????
If it's cracked, shouldn't be hard to feel/see.
Old Oct 25, 2010 | 02:41 PM
TX63CONV's Avatar
TX63CONV
The vertical "crack" (running from lifter valley to deck surface) looks like a shadow from the protrusion in the casting....
Spend the $50 and have it magged and vatted to know for sure....
Old Oct 25, 2010 | 02:42 PM
LonR's Avatar
LonR
Diddo on the protrusion shadow......................
Old Oct 26, 2010 | 09:25 AM
MikeM's Avatar
MikeM
I forgot to mention, the flywheel flange on the crankshaft doesn't appear to be 327 configuration. Appears to be more like the '67 302 shape. Hard to tell for sure from the camera angle.
The oil splash shield is suspect too.
To My 327 Engine
Old Oct 26, 2010 | 03:18 PM
JohnZ's Avatar
JohnZ
The cutout in the 302 crank flange (photo below) is wider than the one in the photos above; has almost the same thickness of material on both sides between the sides of the cutout and the two adjacent bolt holes.
Old Oct 26, 2010 | 03:31 PM
MikeM's Avatar
MikeM
The cutouts in your photo and the one above appear the same to me. The photo above do not look like a 327 to me.
Easy for the buyer/seller to determine though.
Old Oct 27, 2010 | 12:26 AM
60 Gasser's Avatar
60 Gasser
Default Crank Flywheel flange.
The crank in question in my 327 block has 2 cutouts and a locating pin. It's exactly the same configuration as the original crank/engine from my 66 327-300HP.
The stroke in this block is also 3.25" so to me it's a 327 crank not a 302
Am I incorrect with this conclusion? I always knew 283-302 cranks having a 3.00" stroke.
I also cleaned up the block with a brass brush & WD-40 and all the marks (looking like cracks) disappeared.
Putting this one to rest --- now getting the engine cleaned up.
Thanks for all of the insight since the last time I worked on a Chevy engine was 1978. This Forum will be one I frequent and provide my findings from this corner of Oregon
