I have a 64 coupe, the other day it started missing. I decided change the plugs , wires , dist cap and the rotor. The car still is missing. I know this is a hard question, any ideas.
Thanks Joe
If its a constant miss at idle you can pull one plug wire at a time and the one that DOESN'T make the car run worse is where your problem lies....takes 10 minutes to isolate the issue to a single cylinder... If you find the problem...pull and examine the plug and go from there...
If all the cylinders are doing their job then it could be a variety of things....points, fuel, etc.
