Engine Lifting Mount Points
Old Oct 31, 2010 | 01:28 AM
54greg's Avatar
54greg
Default Engine Lifting Mount Points
When lifting a small block I've always perfered using the four outer exhaust manifold mount bolt holes to secure my engine sling. Has anyone any thoughts on the intake manifold/carb hold lifting brackets?
Old Oct 31, 2010 | 03:55 AM
LS63's Avatar
LS63
The lifting brackets designed to bolt to the carb mount have several lifting points that allow you to tilt the engine. I still prefer the engine tilter/leveler that has a spreader bar and four mounting chains. This screw adjustment allows me from banging up the transmission tunnel when working alone.
